-   -   82sc sputtered on highway would not restart (http://forums.pelicanparts.com/porsche-911-technical-forum/270979-82sc-sputtered-highway-would-not-restart.html)
KevinB 03-12-2006 08:48 AM
It does have an old ungo box alarm in it. It does not appear to work. I will chck out the wiring for it and make sure that it was connected properly and take it out of the ignition circuit completely.
Paul, You mentioned the key switch. I will do a search on it. I will search if they do have a problem intermitteltly to not allow power to the vehicle.
Any others?
Kevin B
CliffBrown 03-12-2006 09:56 AM
Originally posted by KevinB
the red relay wasnt popped out. when i got the car home i pulled it out of its socket. it was in their nice and tight.
I will get another one though in case.
Any other ideas?
Kevin B
Kevin
Did you pull the relay out just before you finally got the motor started?
The ignition key will cause a problem like this but I'm not sure it would cause the sputtering you first experienced on the road.
I agree with several others; fuel pump circuit or alarm or key.
KevinB 03-12-2006 10:34 AM
No, I didn't touch a thing before it restarted. After it restarted is when I started to look at items like corrosion or a bad connection on the fuel pump. I pulled the fuel pump fuse and relay to check out the connections and they looked fine. I even warmed up the engine and it just kept on running just fine.
I will take a look at the ignition switch and associated wiring. I will also remove the aftermarket alarm which is non functional anyway.
Thanks for the help.
Kevin B
