Slippery Slope Victim
My butt is finally shaved!
Well as one of the winter projects we removed the bumpr, removed the big ugly bumperettes, filled in all the holes with Al via the MIG.
After all the holes were filled I mocked up the bumper shocks, measuring for centers. I aquired some Al studs and drilld and tapped the now plugged original mounting holes for the studs. Leaving the studs just a tad recessed again plug welded the studs into the material. We then knocked out the studs on the bumper shocks and drilled them out by one size. After a few shmears of filler, using Evercoat Extreme from Eastwood a lot of sanding, primer and sanding and then painting, paint from Paintscratch........it's done. I'm going to use a lit license plate frame for the plate and illumination. The best part is loosing about 22 lbs!
Mike˛ 1985 M491 Last edited by NY65912; 02-26-2006 at 06:01 PM.. |
Looks awesome, this is on my to-do list. Save some weight, clean the looks, and keep crashworthiness. Sounds like a win!
Any pics from the underside?
David Avery 05 Lotus Elise (sold) | 08 BMW 135i visit FocusedE, my e-business company | visit Spyderclub |
Beautiful craftsmanship as ever. Nice work Mike.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Dave, thanks.... it was a fair amount of work sinced we stripped it down to bare metal.
The pics from the work were accidently deleted from my camera, this is what happens when your daughter and youself have the same cameras! I will take pics again, I want to drop the bumper soon to do some other work and it would be better to have the bumper off. I'll add to the post then.
Mike˛ 1985 M491 |
Thanks John, the biggest problem was trying to work with this bum leg of mine! 20 min work then 20 min with leg up in the air.
Not too cahnge the subject but you do know that McSorley's bottles their brew don't you? Me and the Mrs stopped in for a bite in Bayridge Fri nite and the pub carries McSorley's ON TAP!
Mike˛ 1985 M491 |
beautiful sc!
![]() ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
How hard is it to remove the bumper when you need to? how do you do it? Again, looks amazing. I think there is a shop in MA that will do this if you drop off your bumper for close to $1000, which I'll bet given the amount of work necessary is worth it.
Bye, Bye.
Does the front match the back?
Elvis has left the building. |
Dave, the bumper comes off in about 20 min. On an SC or Carrera it's a matter of.....
removing the rub strips, pop out the plugs on the rubber strip and unscrew, a nut behind and it's off. Next is 4 8mm nuts that hold the bellows to the bumpers. Then 4 little screws for the license plate lights on the big ugly bumperettes, disconnect the spade connections for the lights. Remove the bumperettes, there are 3 nuts behind the bumper. That then exposes the nuts for the bumper proper, 4 nuts. And it's off. $1000 seems very high for a job like this. Maybe I should go into business! Scooter...I'm working on fabricating a fill strip for the front for the same smooth look. I'll post when that project is under way.
Mike˛ 1985 M491 |
so the studs and bumperettes weigh about 22 pounds? I am not following, but if so: here we go! Thanks!
1987 911 sunroof - just starting out on that slippery slope =-D |
I wish the butt on my car looked that smooth
![]() Sweet !
1982 SC...Guards Red + Linen |
Bye, Bye.
Your car looks great!
great job! Wasn't there another thread like this but the guy even welded the extension on too? It looked like a RS bumper but in OE steel.
Anyone have the link?
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
Where will you mount your license plate lights?
Thanks.
Fat butt 911, 1987 |
Asjac.... in total (bumperettes, rubber strips) weigh in at 22 lbs.
rnln......I'll be using a lighted license plate frame. Bigrubber.....I'm thinking of doing that mod to the extensions. I've got a full metal fabrication shop at my disposal so it should not be too difficult. I might make a pattern and produce some. Thanks to all for the kind words!
Mike˛ 1985 M491 |
Looks good! I did mine just recently, much cleaner sleeker look...
If you fabricate those extensions I bet you could sell quite a few. I saw an old post where a guy did this and it turned out really nice. I would love to have a pair for front and rear.
Jon |
I'm just looking at doing this too however I think I have decided to keep the rubber strips.
I do think it looks nicer without but where I live and sometimes park I know it will get the off nudge and scrape and I think the rubber strips will take that a little better than a smooth painted bumper. I also think that unless you are going to remove the rubber off the front too it can look a little wierd. I think I'm going to use some of these for the number plate lights - I think done right they will look ok. Uk supplier of light bolts
'89 3.2/3.6 coupe Last edited by jevvy; 02-27-2006 at 05:22 AM.. |
looks great and good idea for illumination.l wonder how it would have looked if you had frenched the bumper for the L plate..
my life begins at 150MPH |
THE IRONMAN
WOW...I have to say: I am impressed.Simply beautiful job...
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
