-   -   Help finding a part # (http://forums.pelicanparts.com/porsche-911-technical-forum/271111-help-finding-part.html)
CHILI 03-12-2006 11:47 AM
I need the steering column bushing. My steering wheel has lots of play in it. You know the one that doesn't have to be removed. You just tap in the new bushing into the column, over the old one.
I can't seem to find it on the site.
Thanks.SmileWavy
RoninLB 03-12-2006 12:00 PM
http://forums.pelicanparts.com/uploa...1142193577.jpg
Is your steering shaft loose, or does it vibrate and rattle while you are driving? It could be that your steering wheel bearing is worn out. Replacing this bearing (sold above) is a lengthy and difficult process, however, there is a Pelican Parts qwik-fix bushing that can be installed in about a half hour. The part that actually fails is a plastic bushing located inside the bearing. This qwik-fix part replaces that bushing and restores the steering wheel bearing close to its original specifications. For complete installation procedures, check out our Pelican Technical Article on Steering Wheel Shaft Bearing Sleeve Qwik-Fix Installation.
Manufacturer: Porsche OEM
Steering Wheel Bearing Qwik-Fix Sleeve, 911/912E/930 (1974-89) $11.75
928-347-739-02-M100
madsonryan 03-12-2006 12:49 PM
Does anyone know the part # for the this bearing on a 67 911?
CHILI 03-12-2006 08:54 PM
Good question. My car is a 69. Do they not have them until 74?
CHILI 03-13-2006 08:59 AM
Monday morning bump.
madsonryan 03-14-2006 08:35 AM
After some research I found it:
914-347-711-00-OEM
