Huh Huh is offline
Mount for door checker
Has anyone had the mount for the door checker break? My driver's side door closes fine but when I open it the door opens almost 90deg. Today I just noticed the rattling from it being broken. Can a plate be welded in the door to mount the door checker or would you guys bother?
'94 VW Jetta
'85 VW Scirocco
'81 911 SC coupe Euro
'67 VW Bug
Old 03-14-2006, 05:57 PM
jeff1hughes's Avatar
our host sells a repair and strengthening piece for it.
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_MISCLL_pg7.htm#item37
86 Carrera Targa - Garnet Red Metallic
88 928 S4 - Gran Prix White
Old 03-14-2006, 06:05 PM
Send a message via AIM to fintstone
Lots of stuff on the topic if you do a search.Here are a couple of links regarding the problem:
SC Door Stop Question
Door stay reinforcement kit
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 03-14-2006, 06:58 PM
Huh Huh is offline
Now that I know the proper name used on this board the search did wonders. How is the repair kit held in place without welding? I am thinking of having a piece of plate metal welded in. What are your recommendations?
'94 VW Jetta
'85 VW Scirocco
'67 VW Bug
Old 03-14-2006, 07:07 PM
There is usually enough metal left around the hole to hold the reinforcement kit. One piece goes on the inside of the hole and one on the outside to sandwich it. The bolts hold everything together. Check out the pictures in the links I posted..and the ones that are linked to in the post..like the one below. There are pictures
Door stay problem
Welding would be even better, but would be much more difficult/expensive IMHO.
Old 03-14-2006, 07:14 PM
Huh Huh is offline
Finstone: Thank you for your knowledge. You have been the common link in all the old threads I have read minus the other threads you have given me. How thick are the reinforcement metal plates? My door stay is a stud/nut type not a bolt in like I have seen with some of the other photos. Will it be thin enough for me to use my original stay?
'94 VW Jetta
'85 VW Scirocco
'67 VW Bug
Old 03-14-2006, 07:26 PM
Wickd89's Avatar
I just had this done a week ago. I gave the parts (repair kit and new stay) to my mechanic (dealer experience for 25+ years and more) and he started to work on it. It turned out that the metal was really bad (kind of obvious but I was hoping), and he ended up having to weld inside the door. You cannot see it after the work is done.
He did mention that it was difficult to work and weld and removing the door skin would have been a better option. Since the door is perfect otherwise, I am glad he was able to finish it going from the inside.
Good luck.
Luis "once was - Wickd89"
Carrera 3.2 - "Faster, Stronger, Better"
-- 2008 Toyota Camry SE V6 (mine)
-- 2005 Toyota Sienna (hers)
-- 1989 911 Carrera Cabriolet -SOLD
Old 03-14-2006, 07:57 PM
The replacement plates are quite thick. Generally speaking, the door does not tear unless the stay is worn out. If that is the case, you will tear out the repair eventually unless you replace the stay. The new stay comes with bolts and nutplates. Although the standard bolts will work, the preferred solution is to use the plated allen bolts. They are much easier to install IMHO. See below
Old 03-14-2006, 08:23 PM
