thebng's Avatar
question about fender flares
This maybe common knowledge, but I need some clarity here! Are SC and C2 rear flares the same? I have someone w/ a pair of 9" SC flares they want to get rid of and was wondering if there was any difference. Like I said, it is probably common knowledge but wanted to go for something a bit wider in the back of my narrow 77S without being totally turbo looking. Thanks in advance.
Old 03-13-2006, 01:03 PM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
same flare as far as I know.....the SC flare is the same flare used on RS/SC/Carrera
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 03-13-2006, 01:28 PM
thebng's Avatar
Don,
Thanks, that is what I thought but just wanted to double check. I hated to post such a silly question, but didn't want to get stuck w/ a set of flares I didn't need either. Thanks.
Matt
More 77 911's than I can shake a stick at.
Old 03-13-2006, 01:32 PM
Bill Verburg's Avatar
Yes, the 964 9" flare is the same as the SC/Carrera 9" flare, except for the torsion bar holes, SC are small, Carrera are large, 964 dna
Bill Verburg
Old 03-13-2006, 01:34 PM
thebng's Avatar
Bill,
Thanks. My plan is to do the C2 rears w/ the C2 rockers and just wanted to make sure they would all mate up when all was said and done. Those rockers would cover the torsion holes if I am not mistaken.
Matt
Old 03-13-2006, 01:52 PM
I would rather be driving
jpnovak's Avatar
To recap what Bill said,
If you use a C2 flare on a 915 or G50 equipped SC or carrera you will not be able to take out your torsion bars to do suspension updates. The C2 had coil-overs so the rorsion bar access holes did not apply.
they will physically fit the car and look the same.
Beware!
Old 03-13-2006, 02:01 PM
I have no experience w/ that mod, but I suspect that you are correct
Bill Verburg
Old 03-13-2006, 02:02 PM
thebng's Avatar
Jamie,
Yes, you are correct! I am looking into different mods now b/f paint to alleviate that problem. I need to figure a way to make the rockers removeable. The C2 underneath looks totally different than the earlier 911's with a tab setup and these clips that lock the rocker in for removal. I know of people that have done everything from glue them on to velcro and tape them on. At the end of the day, i just want to be able to unbolt them to have torsion access if I ever need it. Other than taking the torch out and welding on mounting clips, I see no easy way other than above around the rocker dilemma. Ideas anyone?
Old 03-13-2006, 02:08 PM
