Slackerous Maximus
HardDrive's Avatar
Hood emblem removal/install
I just got a new emblem for the front. I didn't realize how tight the access is to the speed nuts.
A) whats the easiest way to get the nuts off? I am assuming some long needle nose pliars will be involved.
B) how do I get the speed nuts back on? Looks like they will fit into the end of a socket.
I am only asking because the prospect of losing the nuts in that small space is not a happy thought.
"the nuts in that small space" errrrr.......
2014 Cayman S, PDK
Old 03-12-2006, 01:15 PM
I've always used a screwdriver handle that accepts a socket. Never had a problem. A 1/4 extension and socket should work as well.
FWIW, during PCA based Concours (NNJR/Zone 1) it was drilled into our heads that one should very gently bend the badge to conform to the hood contour.
Warren & Ron, may you rest in Peace.
Old 03-12-2006, 02:10 PM
Slackerous Maximus
HardDrive's Avatar
Grrrrrr.....
I poped the thing off by using a screw driver, with a credit card to protect the hood. No problem, except the studs that hold the emblem off broke off. Damn! I REALLY don't want to have to drill this thing out.
2014 Cayman S, PDK
Old 03-12-2006, 02:15 PM
You may try to grab from the underside with pliers and twist out. IIRC, the studs are held on by speed nuts.
Old 03-12-2006, 02:23 PM
Slackerous Maximus
HardDrive's Avatar
WOW.
Was THAT a pain in the ass.
The rubber grommet that comes with the emblem does not fit. I was going to ***** to Pelican, but the OEM one the car appears to be the same. wtf?
Save youself some grief and order and extra set of speed nuts. Its well worth the 50 cents.
2014 Cayman S, PDK
Old 03-12-2006, 05:22 PM
Slackerous Maximus
HardDrive's Avatar
If you have to do this job, the key is that the emblem is very soft metal. Hold the emblem firmly from above after positioning it. Push the speed nuts on until they get to the metal crip on the back, then twist them on. The soft metal of the stud on the emblem gives way and it self threads on.
2014 Cayman S, PDK
Old 03-12-2006, 05:26 PM
scottb's Avatar
A hair dryer and some patience will serve you well here.
1984 Targa
Old 03-13-2006, 12:29 AM
randywebb's Avatar
hot soapy water...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-13-2006, 03:32 PM
Southern Class & Sass
Dixie's Avatar
No need for pliers. The proper size socket and an extension is what you need. It also helps if the PO did not strip the nuts and post when installing the last emblem.
You stated the answer. Use a socket. As posted previously, the gasket takes some finesse.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 03-13-2006, 05:53 PM
randywebb's Avatar
7 or 8 mm
Old 03-13-2006, 06:29 PM
