Fuel Pump Fuse
How hot should the fuel pump fuse get on a 930 Turbo, I cleaned all the contacts, wires and put Dialectric grease on all surfaces. Was fine for a while now is getting warm again to the touch. What should the current draw be at the fuse? Don't know if it is normally warm at the fuse or not. My car is a 1987 930 Turbo with 48,000 miles, I am also having the hot restart issue. I am going to replace check valve and accumulator this weekend. Did not want to spend 301.00 for a front fuel pump if it is not needed.
Thanks for any help
Old 03-14-2006, 12:19 PM
There are two fuel pumps, current draw from either one shouldn't be over 8 amps. If the fuse is getting hot, there is a good chance the current draw is too high.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 03-14-2006, 12:21 PM
You need to read this -->
http://www.pelicanparts.com/techarticles/rice_ramblings/rice_ramblings-2.htm
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-14-2006, 01:01 PM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
This board is incredibly valuable.
I had no idea the old fuse boxes were that suseptible to heat and eventual overload. Probably why I've blown 2 red pump relays already on my 78SC - euro.
(sigh) I can't image a replacement is cheap....
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 03-14-2006, 01:09 PM
I did the Rice modification that Wil is refering to last year on my '88. It works well. Both fuel pump relays and wiring near the fuses stay cool.
Old 03-14-2006, 02:21 PM
OSI,
You were having the same issues with a hot fuse. Did you determine it wasn't the fuel pump?, How loud are these pumps supposed to be?
Old 03-14-2006, 03:01 PM
By the way, I am currently running a 16amp fuse on the pumps right now, I believe that is what is called for.
Old 03-14-2006, 03:04 PM
My fuel pumps are the originals as far as I know and I really don't hear them running as they come on as the engine cranks and starts. I never really noticed my fuel pump fuse was hot as much as my fuel pump relays were hot and the wire to the fuse looked like it has been hot where it attached to the fuse block. I now have two fuses, one for each pump. The Lee rice modification was created to address the problem I think you are having and I had. If you do a search, you will see many examples of this. I sent you a p.m.
Old 03-14-2006, 05:07 PM
Thanks,
I will try the separate fuses first, this will probably solve the issue. I hate to spend 301.00 for a front pump if I don't need it.
Old 03-14-2006, 05:18 PM
