Turn signal stays on after car is shut off
i just bought an 86 911. When i kill the engine while the turn signal is left on, the turn signal stays on constant (not blinking). It only happens with if i turn off the car while the turn signal is still on.
Does this happen to anyone else? thanks
Fun stuff:
86 Carrera
70 Chevy c10
01 DRZ400S
05 CRF250X
longboard
Old 03-13-2006, 08:57 PM
HarryD's Avatar
Yep,
It is by design. That way when you leave your car on the side of the road, you can leave a light on to let traffic know you are there.
Crazy germans!
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-13-2006, 09:01 PM
By design, really...
Doesnt that cause some dead batteries?
Is it only on the left turn signal or right too?
Fun stuff:
86 Carrera
70 Chevy c10
01 DRZ400S
05 CRF250X
longboard
Old 03-13-2006, 09:05 PM
slodave's Avatar
It is with both sides. It will not drain the battery if left on for a few hours at a time. A few days - well, that is a different story.
Dave
Old 03-13-2006, 09:08 PM
Recreational User
porschenut's Avatar
This is why they're called "parking" lights. In most European countries, you are required by law to keep the street-side parking lights on while the car is parked. I think all European cars have this feature.
Old 03-13-2006, 09:16 PM
never ending projects
niner11's Avatar
Dave, I guess the europeans just plug their cars in with big extension cords running to their homes in order to always keep their lights on while parked.
Have not seen a BMW that will run your battery dead if you forget to cancel the turn signal. Just another 911 quirk.
Old 03-13-2006, 11:05 PM
If you use LED bulbs, you could probably leave the lights ON all night.
Sherwood
Old 03-13-2006, 11:08 PM
slodave's Avatar
Not a quirk. Mercedes has the same feature and it is not built into the turn signal. Two side marker lights use 12V and maybe .5 amps. Car batteries on avereage should be able to do 12V/500AMPs.
Dave
Old 03-13-2006, 11:20 PM
