ac evaporator box duct
Help
I am just about finished with new ac system install and need to find the duct that goes from the evap fan housing to the interior. Its 3.25 inches in diameter and about 6 inches long I have been to all the auto parts and porsche dealers and cant find it. I cant find anything in the tech BBS Help |
Southern Class & Sass
Mighty Flow #96093.
It's marketed as the ducting that leads to an engine air filter housing. It's the perfect diameter. At $8.00 for about three feet, it's priced right. Check your local corner parts house.
Dixie Bradenton, FL 2013 Camaro ZL1 |
Well, your description is a wee bit vague, as there is no single duct that goes from the evaporator housing to the interior. And, I am assuming from your name that we are talking about a 1982 SC.
If you are talking about a short hose that goes from the evaporator housing to a plastic distribution piece aft of the smuggler box lid and inside the smuggler's box cavity (this piece feeds the small vent in the bulkhead below the dash, among other things,) you might be looking for 911 571 240 01. It's item number 17 on PET diagram 813-10, if you'd like to confirm we are talking about the same thing. If you don't have a copy of PET, your dealer will. Pelican can order the part for you as well. If that's not what you were needing, let us know and we'll try again. JR
We need not be gracious when our enemy dies. Civility is only afforded those who don't go to their grave trying to destroy us and ours. E. M. Burlingame |
