Southern Class & Sass
Dixie's Avatar
Question A/C oil question
I stopped in to NAPA to buy some R134 compatible oil for the A/C rebuild project in my '88 Carrera. What I discovered is that there are different viscosities available.
What viscosity oil do I need to use?
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 03-13-2006, 05:43 PM
khamul02's Avatar
did not know this. . . An the answer is. . .
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 03-13-2006, 06:25 PM
I used a synthetic oil make by Mastercool called ROK OIL. It was compatible with anything. If you cannot find that, use a esther oil, not pag.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 03-14-2006, 08:30 AM
I'm assuming your car has a Nippondenso compressor (models: 10P, 6E or 6F); if you're staying with PAG oil, a viscosity of 46 is required. Jim
Old 03-14-2006, 07:04 PM
khamul02's Avatar
46 viscosity, thanks, That is the number I was after.
Tom Hutchinson
Old 03-14-2006, 07:21 PM
Dixie's Avatar
Thanks. I'll use PAG 46 oil.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 03-15-2006, 04:02 AM
