-   -   a/c compressor (http://forums.pelicanparts.com/porsche-911-technical-forum/271765-c-compressor.html)
bcr4d 03-15-2006 03:06 PM
a/c compressor
I own a 88 cab and am in the process of replacing the a/c compressor clutch. Is there a special tool to use when taking the old clutch off, or is it straight foward. If there is a special tool, where can I purchase it, and what's the cost. thanks in advance.
bigchillcar 03-15-2006 03:57 PM
send pelican member jim sims a pm...he should be able to answer this.
ryan
Dixie 03-15-2006 04:13 PM
A strap-wrench is what you need. That and a 10mm socket for the nut.
Jim Sims 03-15-2006 04:33 PM
You likely have a Nippondenso 10P15C compressor; check with Autozone. They have a special tool loan/rent program and I believe they have the clutch plate removal tools for this task.
Dixie 03-16-2006 04:16 AM
...and you might want to read thisPelican Tech Article
