a/c compressor
I own a 88 cab and am in the process of replacing the a/c compressor clutch. Is there a special tool to use when taking the old clutch off, or is it straight foward. If there is a special tool, where can I purchase it, and what's the cost. thanks in advance.
Billy Crawford |
send pelican member jim sims a pm...he should be able to answer this.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Southern Class & Sass
A strap-wrench is what you need. That and a 10mm socket for the nut.
Dixie Bradenton, FL 2013 Camaro ZL1 |
You likely have a Nippondenso 10P15C compressor; check with Autozone. They have a special tool loan/rent program and I believe they have the clutch plate removal tools for this task.
...and you might want to read thisPelican Tech Article
