-   -   gauge question (http://forums.pelicanparts.com/porsche-911-technical-forum/271892-gauge-question.html)
qlander 03-16-2006 11:57 AM
gauge question
I'm in the process of removing my gauges to have white faces installed and already ran into a problem.
How do I remove the wire shown here? It seem to be spring loaded. And I thought it'd be easy. I should know better.
Thanks,
Q.http://forums.pelicanparts.com/uploa...1142538981.jpg
Oh Haha 03-16-2006 12:15 PM
Which one?
If you mean the one with the black "sleeve", just gently pull on it. It's a bulb. A tiny bulb. Don't pull on the wire, though.
EDIT: You ARE taking pictures of the wiring before removing, aren't you?;)
911teo 03-16-2006 12:18 PM
Wayne is correct... I did it by levering the ring at the bottom of the rubber sleeve. I used a small flat head screwdriver.
Once it moves a little bit you are home.....
qlander 03-16-2006 12:29 PM
Yes, I'm taking lots of pics with a high resolution camera but it is cumbersome and this was a snapshot with the cell.
Thanks for the advice. I'll post all the pics when it's complete.
I timed this with my vacation since I can't see my baby sitting there in the garage without teeth too long.
Q.
Oh Haha 03-17-2006 05:35 AM
Well, the pics would be more for your use to get the wires all back in the right places but we need new stuff to look at.;)
I know, I'm an a$$.
