Southern Class & Sass
A/C project status: Go!
I started the A/C project today. Removed the compressor, condensors, dryer, and evaporator. Removing everything was real easy thanks to info I've gleaned from Pelican' BBS.
Next up:
I'm looking forward to having A/C on the ride to and from the track this summer. It was a humid 80 degrees today. I suspect spring will be over ver next week, and the hazy, hot, summer, is just weeks away.
Dixie Bradenton, FL 2013 Camaro ZL1 |
Delay installing the new receiver/drier until right before you evacuate the system.
Update:
Flushed all the components, and rebuilt the compressor today....
I used the article in the Pelican Tech Section to rebuild the Compressor. That went really well. Then I decided to take it to the next level and take everything apart. The bearings and everything else looked fine. But let me tell you, getting the pistons back on the wobble plate and into their bores was a challenge. Now I just need to reinstall everything, and recharge. Hopefully the A/C will work well enough to provide some semblance of cooling this summer. If so I’ll spring for some new hoses. I’ll let you know.
Rob, I'm surprised that no one suggested that you replace the hoses while you are at it. I betting 16 year old hoses are on their way out. This is on my list of things to do when I finally re-install my system.
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
What I'm really trying to do is establish a baseline. After that I'll decide if I need to leave alone, upgrade, augment, or remove the A/C system.
Dixie Bradenton, FL 2013 Camaro ZL1 Last edited by Dixie; 03-19-2006 at 03:48 PM.. |
Detached Member
So what refrigerant are you going to use. R134 again, or Freeze 12 or some other derivative of propane and butane?
Hugh |
I'm using R-134. The reasoning is simple. It's cheap, available, and I only have R-134 gauges.
