-   -   Removing the Front torsion bars on a 66 (http://forums.pelicanparts.com/porsche-911-technical-forum/272226-removing-front-torsion-bars-66-a.html)
72 four door 03-18-2006 02:05 PM
I did do a search on this, and was wondering how to remove the torsion bar from the A-arms,but i wasnt finding a whole lot of info surprisingly. The whole front end is out of the car at this time.
djdsc 03-18-2006 06:24 PM
There is a pressure fit cap in the front end of the A-arms. The splines are the same on both ends of the T-bars. Remove the adjusters and tap the T-bars from the rear with a brass punch or wood dowel to pop out the cap and then the T-bar can be removed, tapped out, via the front or the back of the A-arm. Generally they come out the rear. On a ’66 they can be rather rusty and dirty if it has been a while, if ever, since they have been out.
ronw 03-18-2006 06:28 PM
here is a good blow by blow w/ pics. used it earlier this year when i did my front end
http://www.hillmanimages.com/912/front_bushings.html
72 four door 03-18-2006 07:11 PM
Hey thats fantastic thanks so much guys
