Does this 930 tranny have a lsd?
I have a 930 tranny bolted up to a 930 engine which is not in the car and has no axles. How do I tell whether it is a lsd tranny or not?
Thanks- Craig Backer |
Turn one axle flange in the direction of your choice. If the other one spins the same direction than its most likely an LSD . If they spin opposite from each other you do not have LSD.
Also note that very worn internals can cause the spider gears inside the diff to lock causing what appears to be an LSD instead of the open diff that it actually is. I would consider this a rare occurance but it should be looked out for. Without question the best way to evaluate a transmission is to open it up and check it out. But that requires some mechanical skills and should be avoided if your not up to the task. There are also #`s stamped on the bottom of the case that could help identify the box provided it has never been modified or rebuilt. Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd Last edited by pjv911; 03-19-2006 at 11:56 AM.. |
Anyone have any ideas on how to spin the tranny with no axles or axle bolts?
Do you mean NO AXLE FLANGES ? Maybe you should just remove the side cover and post some pictures. Thats very easy to do.
Kurt
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
It does have axle flanges. Just no cv's or bolts.
Just grab the flange and turn, it should be fairly easy to turn if the tranny is out of gear.
You need another set of eyes to help you see the other side as you spin it or a mirror.
Ole Skool - wouldn't have it any other way |
