Jeff Alton's Avatar
3.4 guys, tell me your specs
Hey guys, intersted in hearing the specs of your 3.4 NA motors.
Interested in CR, single or twin plug, motronic intake or carbs or itb's, cam, exhaust etc, and if you know how much power it makes.
Building one right now and still undedided on carbs/itb's and what cam to use.
www.turn3autosport.com
Old 02-08-2006, 10:06 PM
I'll go first:
3.4 Ps and Cs
ARP rodbolts
Raceware springs
964 cams
Single plug
Motronic intake (unchanged from stock)
B&B Headers
B&B muffler (going soon to an MK Exhaust muffler)
Compression ratio 9.8/1
Custom Steve Wong chip
Dynoed with the stock exhaust (including cat) at 207 RWHP or roughly 245 FWHP. I'm waiting to put it on the dyno again until I get the MK muffler, but I'm hoping for another 20hp out of the B&B/MK combo.
Hope this helps.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 02-08-2006, 10:13 PM
Jeff Alton's Avatar
You bet, thanks!
Cheers
Old 02-08-2006, 10:26 PM
Ho ho Ho,
Colin at Ninemeister just got 303bhp from a 3.5 using 964 black plastic induction, and 993 cams.
He's done everything with this engine step by step as its changed customer hands. the latest evolution is the absolute limit.
I think you can find him on here, but probably on (shhh) Rennlist.
or www.ninemeister.com
Old 02-09-2006, 07:15 AM
ttweed's Avatar
My 3.4 is built w/ the Mahle Sport 10.5:1 P/C set, Carillo rods, Aase springs, Webcam 171e and PMO 50 carbs. It is single-plugged at the moment so I run a 97 octane race-gas blend in it. It dynoed at 280 RWHP with a full race setup (open exhaust and big venturi/jetting). In street trim, rejetted w/ smaller venturis and a Pete Weber/Jerry Woods Quiet Horsepower header setup with Phase 9 mufflers and crosschamber, it made 256 RWHP on a Dynojet.
I am really itching to twin-plug it and go to EFI with ITBs, but can't justify the expense at the moment.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 02-09-2006, 07:58 AM
Wow. You guys are making me jealous here.
89 Carrera 3.4
Old 02-09-2006, 08:04 AM
hello.
Theres a guy here in sweden that is really good at tuning porsche engines.
On a 3,2 he takes out 418hp with webers.
Here is a link www.spezialmotorer.com
/Jens
Old 02-09-2006, 08:50 AM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Little larger than 3.4L but close enough.
100mm Mahle Pistons/Cylinders w/ 9.5:1 CR
Stock 74.4mm 3.2L crank & rods
Boat tailed & Shuffle pinned case
Twin-Plug w/ 993 distributor & Andial Signal Splitter
Extrude Honed Intake Plenums
Bored Throttle Body
Web-Cam 20/21 Camshafts
George Narbel's 1 5/8" OD Headers
Monty dual-out sport muffler
Motor makes a peak of 246 whp and 224 torque on Dynojet 248C running 91 octane. Other than the headers, motor passes CA emissions no problem. Close to a 50 horsepower increase with much more low-mid range torque on the same dyno over a 3.2L with chip, pre-muffler and sport muffler.
Andial just finished building a 3.5L LONG STROKE using Mahle 98mm Pistons/Cylinders and a 76.4mm 3.6L crankshaft. Motor is twin-plugged w/ 10:1 CR using 993 distributor and their signal splitter. Still Motronic. Cams are a special grind but I will not post specs. Intake plenums are opened up, polished and welded back together, similar to what Extrude Honing accomplishes. This motor made 297 horsepower on Andial's engine dyno using race gas and powers a 2,200 lb. car with a basic chip. Optimized chip tuning for race gas will increase power a bit more.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 02-09-2006, 09:13 AM
3.4L, autronic EFI, custom cams, arp, full port polish balance and blueprint of everything,
8:1 C/R??
1.1bar boost
490RWHP....
Old 02-09-2006, 09:49 AM
Jeff Alton's Avatar
Derickc, tell me about tunning with the autronic? Did you tune it yourself? easy? difficult? are you using it for iginition as well?
Old 02-09-2006, 03:45 PM
Jeff,
I didn't. It was Stephen at Imagineauto.com. I do know he had some issues with it, so you may want to ask him if he would recommend the system. I think the conventional wisdom is that it is a very well designed and flexible solution without much technical support...
-dc
Old 02-09-2006, 03:57 PM
jakermc's Avatar
Originally posted by Jgordon
I'll go first:
3.4 Ps and Cs
ARP rodbolts
Raceware springs
964 cams
Single plug
B&B Headers
Hope this helps.
I may be building something very similar. Can you tell me what timing your 964 cams were set at?
1983 911 3.6L - NASA GTS-3 class
1998 Boxster - PCA SpecBoxster, NASA GTS-2
2003 996X51 - NASA GTS-4, PCA GTB
2003 996 Carrera 2 Coupe
2003 Ferrari 575M
Old 02-11-2006, 11:54 AM
3.4l Mahles 10.2/1, twin plugged, Andial spark splitter, 964 distributer, 20-21 Webcam regrind, bored throttle bdoy, Extrudehoned intakes, polished ports, arp bolts, race springs, SSI's, custom Magnaflow dual exhaust, Custom tuned Steve Wong chip, Prior to last rich running chip , 230hp at rear wheels.
Old 02-11-2006, 01:25 PM
1.1 bar of boost is cheating a little.
got a friend with a 790bhp 2 litre beatle, fubar of boost.
Old 02-13-2006, 10:35 AM
not if you build it right. It's built to handle 1.3 or so and we backed it down so it'll live longer. Keep in mind that it doesn't hit full boost until third gear and if you keep your foot in it for more than about 10 seconds your are over 150 mph...
-dc
Old 02-13-2006, 11:36 AM
MBruns for President
JeremyD's Avatar
Guess I need to add to this
3.4 Mahle 9.8 to one
Extrude Honed intake
Bored throttle body
993 super cup cams
ARP rod bolts
Supertech head studs
Single plug
964 B & B Headers
Magna Flow dual out SS Muffler
Race Springs - Titanium Holders
93 octane gas from the gulfcoast
Steve Wong custom chip
244.3 rwhp first round of tuning on a Dynojet 248c
Old 03-21-2006, 01:42 PM
Jeff Alton's Avatar
Thanks Jeremy!
Cheers
Old 03-21-2006, 02:26 PM
