Clewett Engineering spark plug wires - are they a good replacement?
I need to replace my '87's iginition wires and find the stock Beru's really too expensive for what they offer, mediocre performance. I've heard you can't run a high-output coil with the factory wires, they may short to ground. The Magnacor's seem to offer some improvement but have some issues with fit. I would like to run the Nology high performance coil so I can increase the spark plug gap to about .035" to .044". Will the Clewett Engineering wires handle this task?
Try the 7 or 8 mm Magnacaors ( black...blue),..instead of the 8.5 and 10 reds.
- Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Why not the reds?
1985 911 Coupe Black 1985 911 Cab GP White (killed) |
i am running clewett , stock coils, dual distributer. runs a hell of a lot better than bad old wires i had.
they are a very tight fit around the coil due to MEGA rubber boots. Other than that...they look good and feel strong.
Have you ever felt suffocated while watching the Oxygen Channel? People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself. 88 Carrera |
Why not do a search and see what other had to say?
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
abit off center
Just get some bulk Beru wire and some M3 ends and make a new set or fix the bad ones.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
I installed some on my 84 a couple of weeks ago. Noticeable improvement over the originals. Then again most anything probably would have been.
UFLYICU
Check this thread before you buy the Clewetts.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
UFLYICU
I bought a pre-assembled set of wires from kingsborne with the M3 ends, separators and heat sheath for about $100. Screwed on my old Beru connectors with some dielectric grease, and I'm happy as a clam so far. No moisture issues, and I got to pick any color I wanted.
I have had zero issues with my clewetts. My '89 Carrera runs much better with them. Some folks had problems but mine have been great.
1989 Carrera Targa - - Guards Red |
also a note...the problem was posted almost a year ago.
Id think Clewette would have fixed it.
UFLYICU
It's easy to tell if the issue was fixed. If the heat sleeve is inside the boots, it's gonna wick water inside sooner or later. At the very least, there should be a silicone bead to seal each boot on both ends of the wires. The fix that Clewett did was to wrap a piece of shrink tube around each end without pulling the heat shield out of the boots. That will just delay the wicking problem IMO.
Less brakes, more gas!
I have the red Magnacore's... work great, but they are too short to run in the OEM locations. I was thinking of buying some wire and making my own this time around...
-m
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Installed Magnacore's about a year ago, great wires. They seal tight so no issues in the rain and the red is mighty purdy.
UFLYICU
Check out the Kingsbornes . I'm really pleased with the quality, and there are a ton of colors to choose from.
Why not Reds?...
The fat wires are mostly fatter on the insulation only....now you've got hard-to-snap connectors on an overly-crowded dizzy....as well as tight fitment within each of the wire holder/separators....best to drill them out to some larger ID.... Etc, etc.....the smaller blacks don't need this fiddle-farting... - Wil
