Kelly Bell's Avatar
Fender flare question
I have a question re turbo flares. I am considering putting them on my 75 911s project. Has anyone done the fibreglass flares? They are so much cheaper than the regualr flares. What is the difference?
Also, how do you put on the fiberglass ones, since you cant weld them in, like a patch panel.
Thanks!
Kelly Bell
72 MGB
75 911S
00 Volvo S70
Old 03-21-2006, 03:45 PM
I'm with Bill
Rick V's Avatar
As for attaching the fiberglass ones I can't answer as for the steel ones you "should" use them. Steel is more colorfast and it won't turn to spider webs from the rocks and road debris that will be hitting the underside. We just had a thread like this one. Try the serch Your question will be answered
Old 03-21-2006, 03:54 PM
WOLVERINE's Avatar
check out *************** ,they have steel ones and are made by dansk,according to one of their sales people
1977 Porsche 911S (Widebody)
Old 03-21-2006, 03:58 PM
i got a set of flares from TRE (metal), sometimes they even have used ones available. could you use rivits to attach the fiberglass ones?
*NEW 1969 911t targa soft window option
1967 912 Targa Soft Window
1989 911 GP White Cabriolet
1970 911t
2001 Chevy Silverado 1500
1997 Audi A4 Quattro 2.8
2003 Acura TL Type S
1973 911t 3.0 track car (SOLD)
Old 03-21-2006, 04:07 PM
Non Compos Mentis
Usually, fiberglass is glued on.
Old 03-21-2006, 04:09 PM
Kelly Bell's Avatar
If they are glued on, then do you fix the seams with bondo?
Kelly Bell
72 MGB
75 911S
00 Volvo S70
Old 03-21-2006, 06:09 PM
87924gt's Avatar
Lots of work
The steel flares are VERY labor intensive, but the outcome is well worth the time, effort and money!
My life is great!
Prev. rides - 87 924GT, 86 Carrera, 69 Targa, 85.5 944 track car, 86 951
84 Triple Black 911 - Current
Old 03-22-2006, 01:33 PM
Non Compos Mentis
Yup.
Old 03-22-2006, 04:47 PM
I would make the effort to go metal. the P.O on my 69 installed GRP flares. They were actually installed with the help of some kind of blind rivet. After many years you can now see the line of raised heads along the attachment line. I assume there is some kind of corrosion going on there or the rivets have loosened or somthing. So far there is no broken bubbling, the surface appears quite solid so I will leave alone for a while
Steve F
69 911
71 911
87 Carrera
2004 RAM 1500 4x4 "Hemi"
Old 03-22-2006, 06:42 PM
