-   -   Quick question on engine plug (http://forums.pelicanparts.com/porsche-911-technical-forum/272784-quick-question-engine-plug.html)
Ashley Bowler 03-21-2006 12:43 PM
Quick question >>>>
<img src="http://img.photobucket.com/albums/v58/ashley1888/DSCF0012-2.jpg">after looking at the engine, I noticed a small round black rubber plug, about the size of a dime. When the plug is removed there are 3 metal contacts. Can someone tell me what this is? Thanks in advance!
cgarr 03-21-2006 12:44 PM
I think its only a test port to indicate TDC on the flywheel
Ashley Bowler 03-21-2006 03:09 PM
Huh??? Without me sounding like a complete dope...........could you tell me what "TDC on the flywheel" means?? :confused:
bigchillcar 03-21-2006 03:21 PM
refers to a mark that can be seen only with the engine running and normally with a timing light device on cars without a 'testing port'. provides information needed to properly set the engine's timing. do a search on 'timing' and you'll learn all about it..
ryan
Jeff 03-21-2006 03:22 PM
TDC stands for Top Dead Center.
cgarr is correct, it is a diagnostic plug that connects to another speed sensor.
Ashley Bowler 03-21-2006 03:32 PM
Thanks guys. I do like this Forum. It's a mix of great technical info coupled with some wonderful and entertaining humor.:)
cgarr 03-21-2006 04:49 PM
So were being laughed at? :D
Wil Ferch 03-22-2006 01:06 PM
That's *we're* being laughed at....as in ...we-are being laughed at .....
- Wil
