Me like track days
Craig 930 RS's Avatar
Question Emission test - 'trick'........heard of this?
"Remove and plug one of the injector lines at the fuel head, lean it out, dial in the idle and limp to the testing station.."
Heard of this method?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 03-22-2006, 09:01 AM
Wider is Better
wholberg's Avatar
No, but it sounds like you turn one of your cylinders into a big air pump.
Wider is Better
Old 03-22-2006, 09:05 AM
Non Compos Mentis
Haven't heard of that.
My 944 still passes Washington state smog, even though the cat was removed long ago. It's not too tough to pass smog here.
Unless you have an early RX-7.
But that's another story.......
Me like track days
Failed by 2X with CO. If you lean it out too much, the HCs rise.
930s are hugely notorious for being hard to pass WA State emissions, FWTW.
Old 03-22-2006, 09:10 AM
youngkang's Avatar
If you have an injector with tips welded shut, I heard it works wonders.
I remember someone doing that to pass their smog inspection after failing 4 times.
Old 03-22-2006, 09:17 AM
Chuck Moreland's Avatar
I had a vehicle fail the sniffer because it had an exhaust manifold leak. Air was getting in and the sniffer detects this.
Seems that having a cylinder air pump would do the same thing, only much more so.
On the other hand some cars, including my 77 911, have an air pump that does nothing more than blow fresh air into the exhaust manifold. Go figure.
This is in CA so your mileage may vary.
Chuck Moreland - elephantracing.com - vonnen.com
Old 03-22-2006, 09:27 AM
Huh Huh is offline
I have been told by a mechanic that if you play with the mixture you can get it to pass. If you are on the high side of the HC then you slightly lean it out and visa/versa. The car may run like dung but it will pass, then reset it back.
'94 VW Jetta
'85 VW Scirocco
'81 911 SC coupe Euro
'67 VW Bug
Old 03-22-2006, 09:30 AM
abit off center
cgarr's Avatar
Originally posted by Huh
I have been told by a mechanic that if you play with the mixture you can get it to pass. The car may run like dung but it will pass, then reset it back.
So its really just a big game
______________________
Craig
G2Performance
Old 03-22-2006, 09:36 AM
Huh Huh is offline
Yes but here in Indiana most of the state is not required to do inspections or emission testing. I am not really an advocate of it but hey if you need to buck the system do at your own risk. I am sure it will come back 2 fold then.
One can always try guaranteed to pass additive too.
'94 VW Jetta
'85 VW Scirocco
'67 VW Bug
Old 03-22-2006, 09:39 AM
Virginia Rocks!
VaSteve's Avatar
Yes. Emissions is for the 4 million Hondas out there. This is a high performance car used infrequently so I don't feel too bad about the pollution. Make the trees work a little harder.
I do feel bad about pouring 12 quarts of oil down the sewer when I change it. That's twice as much as my other cars.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 03-22-2006, 09:40 AM
Me like track days
Steve, that was gooood......
Old 03-22-2006, 09:55 AM
Re: Emission test - 'trick'........heard of this?
Yes, I've heard of that and as wholberg says, it turns one of your cylinders into a big air pump.
When my Carrera wouldn't pass I noticed the O2 sensor was unplugged so I was running too rich. After plugging it back in I passed with no prob.
If you still have problems passing, scan and post your test results here. Someone here is bound to know exactly what the prob is.
-Steve
'87 Carrera Targa
Old 03-22-2006, 09:58 AM
rsrfan's Avatar
Craig,
John Walker posted about this last year when I was looking for a way to pass. For what its worth, I needed a cat on my 930 to get by. With the cat it was clear sailing.
JP
JP
86 930/4 tribute beasty
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 03-22-2006, 10:02 AM
Me like track days
I was going to install this:
Old 03-22-2006, 10:05 AM
Jeff Alton's Avatar
I first heard that trick for a 3.2 from John Walker. Of course all you have to do on a 3.2 is pull the injector wiring off the injector. The theory sounds good....
Cheers
www.turn3autosport.com
Old 03-22-2006, 10:25 AM
Craig -
I thankfully just finished battling with getting my 930 to pass emissions. As I remember I was 2x the legal limit of burnt fuel and 3x the legal limit of unburnt fuel when I first tested the car. On a more positive note I did pass the fuel filler cap test . I ended up having a muffler shop weld up a small cat and resonator that would fit in place of my Borla muffler. By the good grace of the Porsche gods I passed! I'll try and get a picture of my contraption. Obviously immediately following the test I put the Borla back on!
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 03-22-2006, 10:28 AM
Blanco's Avatar
I hear you can leave a $100.00 spot on the seat and just look the other way.
Just got mine to pass so I know what that feels like.
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler
Old 03-22-2006, 11:25 AM
Me like track days
Cool. Thanks guys, good to hear the experiences.
The catalyst did the trick last year.
This is the final emission test - the car will be 25 when the next test rolls around in 2 years - past the required range of tested cars.
Old 03-22-2006, 11:30 AM
Automotive Monomaniac
Emission's Avatar
I had to... um... "borrow" a good CAT to get it to pass. I'll be doing that again soon...
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 03-22-2006, 11:35 AM
Me like track days
Well damn "Emission" IS your name......
Old 03-22-2006, 11:40 AM
