Dottore's Avatar
2 in - 1 out SS muffler for 89 3.2 liter Carrera
I have just had the heat exchangers on my 88 3.2 liter Carrera replaced with SSI units. This means going from a 1 in - 1 out muffler to a 2 in - 1 out muffler. I am looking for a nice SS unit to complement the SSI's - but have so far only found a Dansk with a very tiny pencil-dick tip that looks rather silly.
Does anyone have any recommendations? I would like to stay with the "1 out" tip if possible - and this should have a diameter of at least 4 inches.
_____________________
These are my principles. If you don't like them, I have others.—Groucho Marx
Old 03-27-2006, 02:49 PM
Will program for food
ghnat's Avatar
You should check out M&K mufflers. Our host sells them.
I have a 2 in 2 out just ready when my car is reassembled.
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 03-27-2006, 03:25 PM
Registered Cruiser
jorian's Avatar
I have the pencil-dick you are referring to. On my car that is. Very happy with the performance and sound. If you don't like the exhaust tip, cut it off and weld on something ricier. Any muffler shop would do this and probably has some tips you might like.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 03-27-2006, 03:35 PM
petrolblue83911's Avatar
Nice description on that! I suspect I also have the p-dick system.. do a search on resonance/exhaust and you may find out why the dansk is so popular. Many of the "coffie" can mufflers resonate horribly, leading their owners to switch back to something closer to stock, so keep this in mind
Old 03-27-2006, 03:58 PM
Dottore's Avatar
I meant no offense! It seems odd that with the all the aftermarket brands and permutations around - no one seems to make a nice SS muffler for 2 in 1 out configuration - with a decent diameter tip.
Old 03-27-2006, 04:07 PM
jakermc's Avatar
I'll be selling this 2in/1out muffler in about 2 weeks. I was running it on my Euro 3.2L with headers. Nice sized diameter. Let me know if you are interested in it. I'm putting a 993 engine in, thus the sale.
http://pg.photos.yahoo.com/ph/rmcohen@sbcglobal.net/detail?.dir=dca3&.dnm=ef1are2.jpg&.src=ph
1983 911 3.6L - NASA GTS-3 class
1998 Boxster - PCA SpecBoxster, NASA GTS-2
2003 996X51 - NASA GTS-4, PCA GTB
2003 996 Carrera 2 Coupe
2003 Ferrari 575M
Old 03-28-2006, 04:59 AM
MBruns for President
JeremyD's Avatar
I wouldn't call the MK weenie muffler
great quality - great sound.
of course you can also go with a magnaflow if you want...
Old 03-28-2006, 06:16 AM
JeremyD's Avatar
GHL also makes a dual in - single out with 4" tip
http://www.ghlmotorsports.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=911MDS4&Category_Code=911DUAL
Old 03-28-2006, 06:21 AM
"At least" 4 inches ?????? ( I mean , really....at "least" ???). So, you mean...like 5" or 6" would be OK ????
I would suggest taking a tape mesure to your car so you can "see" what 4" looks like. It's enormous and almost caricature-like...IMHO
Understand that stock is something like 1.5-1.75"
Oh...and the 917's ended up with something like 2" diameter terminations ( !)
Super large exits not only have the tendency to resonate, but the exit gas velocity drops so low that oil-film smuddging of the surrounding body is a real concern...but to each his own I guess....
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-28-2006, 06:24 AM
JeremyD's Avatar
Hey, he has a TL
Old 03-28-2006, 06:26 AM
"Hey, he has a TL"...
Oh.... yeah..ahh, yeah...that's it......
- Wil
Wil Ferch
Old 03-28-2006, 06:42 AM
Dottore's Avatar
Actually, my old muffler (1 in - 1 out) was an original Porsche part (I'll dig out the part number if you are interested) - and it had an 11 cm (or 4.25 inch) diameter.
This was a SS muffler sold by Porsche dealers in Europe (where I bought it) - and manufactured for Porsche by Dansk. I will post a photo of this later. It looked great, sounded great and had no resonance problems. Unfortunately it will not mate with the new SSI's.
Old 03-28-2006, 06:51 AM
IMHO the 3 inch and larger are overkill. The 2.5 tips are more then enough and the factory was only about 2 inches. The dansk are nice mufflers. I would suggest staying away from the flowmaster style set ups as they are way to loud IMO. Good luck
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 03-28-2006, 07:09 AM
try here....offerings include single/dual outlet up to 100mm each ( ~ 4")..
http://www.montymufflers.com/pages/carrera.htm
- Wil
Wil Ferch
Old 03-28-2006, 07:29 AM
PS- do understand this rather unique issue too.....
The Turbo-Look cars use the slightly different semi-trailing arms that are also used for real Turbos. Real turbo's won't run SSI's...but that mix CAN be used for normally-aspirated 3.2's in Turbo bodies...the "Turbo-Look" cars.
Seems to be the case here....
It's been my experience to see rear shock body interference with this set up...such that the SSI heat exchanger flanges ( horizontal "seam" on the heater- heat exchangers) hits the shocks.....
No real cure for this...expect some scraping unless you can "bend" the HX flanges a bit but risk causing a break....
- Wil
Wil Ferch
Old 03-28-2006, 08:05 AM
Friend of Warren
I also have the p-dick tip on the Dansk. I also have a mig welder. I have switched outlets as it only takes about 10 minutes to cut the old outlet off with a sawzall and weld on a new one, but went back to the 2" outlet as I liked the sound better. I would recommend getting the Dansk for the quality and sound and then put on whatever outlet you like.
Kurt V
Old 03-28-2006, 08:16 AM
Danskman's Avatar
Dansk does make a sport muffler for the 3.2 with the SSI setup that comes in either single or dual out 84mm tip(s).
Dansk part number 92.512S (single out)
Dansk part number 92.512SD (dual out)
Available from our host.
You can go to www.jpgroup.dk to see catalog listing and pics.
Mike
'80 911SC Weissach Edition
'87 325is
'02 K1200RS
Old 03-28-2006, 08:57 AM
Why don't you ask Ben (mb911) at MK to make you one with a 4 inch tip? It says on their website (http://www.mkexhaust.com) that they'd do custom stuff, so I'm sure they would. I've heard that these exhausts are the best available.
Charles
'84 911 3.2
Old 03-28-2006, 11:16 AM
Guys, guys...the numerous hints for the dual out Dansks using the 84 mm tips just WILL NOT do...I mean...they're ONLY 3.3".
Didn't you hear the man..he wants 4" MINIMUM....what are you all thinking ???
- Wil
Wil Ferch
Old 03-28-2006, 11:35 AM
Nine9six's Avatar
Another recommendation would be a Fabspeed. www.fabspeed.com
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 03-28-2006, 11:50 AM
