Use your A/C to cool your engine!
I was just daydreaming about ways to increase engine cooling in my 3.2, and I'm wondering about the potential effectiveness of using the A/C blower output in various ways, such as:
1. Redirect the blower output from the smuggler's box to the front oil cooler instead of the car's interior. 2. Relocate the AC evaporator/blower to the engine compartment where the heater blower normally is. Since you don't need heat in the summer, that stuff can come out anyway. Connect the blower output to the heater tube connected to the fan shroud. Not only would cold air be added to the fan’s airflow, but the blower draws hot air out of the engine compartment and circulates it through the evaporator. 3. Do #2 above, and also add Grady's Rubbermaid Solution by inserting a misting nozzle into the cold air stream as it enters the shroud area. And since your smuggler's box is now empty, use it to house the Rubbermaid water supply. 4. Instead of blowing the cold air on the engine, instead connect the blower output directly to the horn on the airbox cover, thereby feeding it cold intake air even on a hot day. The A/C plumbing for the evaporator relocation would require a short 3' run from the compressor to the evaporator, and a longer run from the front condensor to the evaporator. Any of these ideas have potential? |
dave..tell the truth..your unemployed right now, man..;)
ryan |
... in this house, we obey the laws of thermodynamics! ...
(no AC, but installing a fan on the oil cooler is workable) (added thought - we keep calling our cars air-cooled, but are they not oil-cooled?) |
Can I disconnect my oil cooler then?
ryan |
Re: Use your A/C to cool your engine!
Describe a scenario. |
...I think #3 has good bang for the buck.
But consider going with a nalgene-tank of say, 12 - 15 gallons...That would increase your capacity. It would eliminate the cords (bungee) especially if it was a factory look molded fabrication - fitting the 911 bonnet shape perfectly. BTW, there are many more threads on this board 'inviting' more heat - not less. Hopping up a motor almost always produces more. If you dissassemble the motor and drop the compression from 9.8 to 9.0 - you would achieve some benefit in cooling the motor. A few guys here would be unhappy at 8.5 or 8.0. UNLESS, they lost a MAJOR amount (3-400) pounds out of the car. Probably, you could live quite nicely running 8.0 to 1 compression at 1800 lbs. What 911's really need is a kind of ultrahightech solar 'still' that could help replenish some of the supply of water for your mist. From what I know of stills, they tend to produce only a few ounces of water at a time. Phil _________ '74 fiat 128 '80 928 '82 Targa - sold |
Guys,
Give Dave a break for “thinking outside the box.” This is where wonderful ideas come from. I think all the engineers should calculate the HP benefit from cold intake air compared to the HP cost of running the A/C in reverse. My gut (thermodynamic) reaction knows the answer but I would like to see it on paper before dismissing Dave’s proposal. Of course my two favorite (sucessful) solutions are the engine cooling fan ratio and the “Rubbermaid Solution.” Best, Grady |
You can generate a refreshing breeze in a hot gymnasium by running some laps. ;)
ryan http://forums.pelicanparts.com/uploa...1143237382.jpg |
There's a real shortage of hot tea while I'm driving - how about using the oil-cooler's heat to boil some water that's accessible from the cabin, while simultaneously running my engine cooler?
Babak |
ianc |
a little over 2 hours and we STILL have failed to re-engineer the car's ability to dissipate heat to any appreciable degree! we must need more minutes..we'll get there..;)
ryan |
I suspect driving technique is a possibility. I had to learn to adjust gearing during Rocky Mt rides. A CHT was a big heads up that registered way before oil temps. Once the oil was hotter than desired it was a pia to cool down.
umm..yeah..i crunched the numbers..and..uh..what jim said! ;)
ryan |
what about my question.. huh?
If conventional wisdom and popular notions were never challenged, there would never be any advancement. I challenge conventional ways of thinking all the time. Ya win some, ya lose some.:) |
| All times are GMT -8. The time now is 05:20 PM. |
