Oxygen sensor removal
How does one disconect the wires running to the oxygen sensor before unscrewing it from the catalytic converter?
Old 03-26-2006, 06:56 PM
Autobahn Garage
What year car? There is a plug in the engine compartment unplug it and pull the wire clear
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 03-26-2006, 07:04 PM
87 Carrerra. There is a disconnect in the engine compartment, but the wires are immobilized by a grommet (?) in the wall between the engine and the wheel well that would preclude the wires from turning freely.
Old 03-26-2006, 08:10 PM
Will program for food
ghnat's Avatar
You don't... Unless you are replacing the sensor and in that case just cut the wires. There is a tool you can buy - it has a slit cut in it. Our host sells them.
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 03-26-2006, 08:13 PM
Yes...you can use a socket designed for this pupose. It allows the wire to be in place when you secure the socket.
If you have to replace the sensor you can cut and pull the connector and sensor and replace with a new OEM unit. If you want to save some $$$ buy a generic and use the supplied splice to utilize the original connector with the new sensor.
Warren & Ron, may you rest in Peace.
Old 03-26-2006, 08:19 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Pull the grommet to allow the sensor to turn. I sliced mine from each hole to the outer edge and re-used it with a new sensor. You can place the new wires into the old grommet by pushing them through the slices, and then just re-install the grommet after you've tightened up the new sensor.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 03-26-2006, 08:22 PM
Autobahn Garage
Or just pull the plug slide the wires out of the hole and use a boxend wrench to loosen the sensor
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 03-27-2006, 04:02 AM
Thanks much for the input!! Tab's solution worked; there's plenty of room for a box wrench, at least in this '87...................
Old 03-27-2006, 06:43 PM
