Quick Brake Line Question
Buying SS brake lines from our host and need to know the size of the flare-nut wrench that i need to do the job?
Also - I want to flush the entire brake system, how much brake fluid do I need to have for this project? Thanks!!
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
David,
I can't remember the exact sizes but Sears carries a multi size pack for a good price. You end up using more than one. as for fluid I would count on at least a quart, maybe more depending on how much air gets in the lines. When I did a full rebuild, including calipers, it took a few quarts before I had it right. YMMV -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
OK thanks!!
The flare wrench needed is 11mm.......I bought mine from Pelican. I come with a 9mm on the other end. Just used it yesterday. Replacing my master cylinder & doing the pedal cluster thing.....
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
one quart of super blue (blue or gold) is plenty of fluid for a full flush. If you are using a clear fluid, use super blue so you know when the new stuff has reached the caliper you are flushing. Use a fresh can and only open it when you are ready to do the flush.
Tony G 2000 Boxster S |
At least that's how mine went and other guys' too.... -Chris
