 H5 to H4 Headlight conversion plug?
		Hi,
	Can someone tell me how the plug adaptor is used when converting from H5 to H4 headlamps? I ordered everything from Pelican and received two adaptors for the light connections, but am not sure if I am cutting off the existing plug or what to do with it... Any clues? Thanks, Mike  |
 plug pic
		forgot to add this to my post...http://forums.pelicanparts.com/uploa...1143414518.jpg
 cut and plug
 I went through the same thing.
	buttjoint is right. You have to cut your wires, but pay attention to where they go in relation to your old light. After they are cut and stripped, you need to push up on side with the holes and insert the wire. Do the same fo reach. The side that has the holes is pushed on to your headlight. http://forums.pelicanparts.com/uploa...1143423073.jpg  |
 excellent...thanks guys!
	Mike  |
 Pelican lists the plugs as no longer available.  What is the alternative for the plugs to convert the headlights to h4 lights?
	thanks eric  |
 Go to Autozone or Pep boys (any parts store) and P/U a H4 plug end and wire it up...About $9.00 a plug IIRC
 Thanks!  I will try the Marcus Sucro  relay as well.
	thanks eric  |
 the Sucro kit is great...but you do understand that his kit is for running the higher voltage lights and has nothing to do w/the connection in the headlight bucket.
| All times are GMT -8. The time now is 05:33 PM. |
