Sunroof removal?
Sunroof removal?
Can someone give me a step by step or tell me where to find the process for removing a sunroof on an 88 911.
1988 911 Carrera 1970 911T 1972 911E Roller |
Going from memory here... Open about 1/4 way. Inner cover snaps out at the front. Slide inner cover towards back of car. SR attaches to rails with 2 bolts. I think there is also an adjustment for height in there too. Once loose from the rails/actuators, move towards front of car and pop up. Not much too it. Have done it in an MB and they are all pretty much the same. Lou
'76 911 "Moneypenny" daily driver '74 911 "JLo" IROC DE Car '03 CRV, '02 Jeep Grand Cherokee '03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft# http://www.nicotra4.hpshare.net/BasketCaseMotorsports/ |
Yup - that's pretty much it. It's self explanitory as you start unbolting stuff. Unzip the rear headliner to disconnect the cables from the transmission, you can side the sunroof back and forth manually
Are you contemplating a permanent removal or a temporary one? I just did a permanent removal...
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
I have been planning a permanent removal, what did you use for the delete? How did it turn out?
14 Cayenne Turbo S 06 Cayman S 87 911 becoming 73 RSR Mary Stuart 68 TVR Tuscan LWB 66 TVR Griffith Series 400 |
From this: Now to this:
Don, tell us about the headliner would you..... I believe you "promised" in an earlier thread. Was the tacking done with a mig or tig? No heat spots showing at all on the outside skin??
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
