extreme technical problem
Not really! I have a Momo gear knob and I wish to instal the remains of a stainless [I think] keyring into the top.as pictured.
Before I find a lathe and try to machine the existing top away,so I can glue the new top in, does anyone know if these things come to bits? The knob is almost new and I flicked out the top plug to reveal what looks like a centre hole ,but thinking about how they got the leather in suggests that it might unscrew .---Anyone? http://forums.pelicanparts.com/uploa...1143438050.jpg http://forums.pelicanparts.com/uploa...1143438079.jpg |
One word:
Epoxy. If it falls out later... then worry about it. |
Look at it from the bottom, I have a chepo shift Knob & yea the hole thing comes apart. On mine looking up from the bottom revealed a screw. On yours it might be an alan or torx so keep a sharp eye.
wait for the specialists to chime in.
I can't get a good look at the top of the shift knob, because the photo is a little fuzzy, but you might try uncrewing the top by using a pair of pliers designed to remove and install c-clips.
JR |
Had a look up the bum and couldnt see much,so I picked out a rubber sleeve [which is now damaged]
Couldnt see anything like a screw,so I put a long 3/8 socket extension up and tapped it with a BFH. http://forums.pelicanparts.com/uploa...1143460907.jpg The brown material which broke looks like wood. The keyring fits perfectly, so all I have to do is build a bed of epoxy to assemble it and take care when re-installing it on the gear lever.----Problem solved! http://forums.pelicanparts.com/uploa...1143461365.jpg |
Well done! It turned out nice. Feels good to have something no one else has don't it? http://www.pelicanparts.com/support/smileys/wat6.gif
Nice... make a few more and make $$$$
| All times are GMT -8. The time now is 04:06 AM. |
