Adjusting Koni front shocks
Can I adjust my Koni reds while they are installed in my SC? Or do I have to pull em?
Matthew “Sometimes the questions are complicated and the answers are simple.” |
depends on the type...
did you do a search?..... try this one and look at what I say ---> koni shock adj. quick test..I did a search of terms "Koni" and "adjust" and I found 3 pages of threads !... - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
You have to undo the top nut (in the trunk) and let the suspension down, dont let it hand on your brake line though. Then compress the shaft until it finds the slot ..... you probably know the proceedure.
You can leave it in the housing but you have to get the top of the strut out from unde the fender. Really not a big deal but takes an hour probably to do both sides.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
My front Koni reds adjust with the turn of a knob. Takes about 15 seconds...
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Thanks EW, thats what I was looking for.
...then again mine didnt come with a nob, but I didnt have to compress them. I found info on their website and adjusted them using an hex wrench.
I adjust them on top (in the trunk). I'll take a picture..be right back. :>)
Mike
*twiddles thumbs* ![]() (thanks much!)
OK, here's the top of the strut:
And here's a blurry one (sorry) with the knob installed:
Thanks! That helps a bunch.
Iroc you need some Monoballs on that bad boy ;-))
Mike
Mike, its my thread so im taking it OT. Can we see some full body pics if you got em?
In my first reply... I suggest that the embedded thread be read.
If we do this, you'll find my statement..." If you have a small "blade" on the very top / center of the big strut shaft..you have an externally adjustable shock that does NOT need to be demounted to adjust. ". Doesn't anybody respond to answers anymore ??? .... ![]() In the meantime, Porscheguy79 sez , " Thanks EW, that's just what I'm looking for"...( answer that says drop the whole shock and compress/adjust)... Well alrighty then....you're very welcome !! - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 03-27-2006 at 07:32 AM.. |
