Addicted to Racing
edbaus's Avatar
Question on early cv shaft liniage
OK,
So here is how I understand the different generations of cv shafts/drive flanges/stub axles.
The early cars (pre 69?) had 4 bolt large bolt pattern setup. Used 4 10mm bolts and 2 pins.
The next generation (70 - 78?) used corse splines on the drive flange, 6 8mm bolts on the cv shaft, and course splines on the stub axles.
The next generation (78 - 83?) used fine splines on the drive flange, 6 8mm bolts on the cv shaft, and ???? splines on the stub axles.
The next generation (84 - 86) used fine splines on the drive flange, 6 10mm bolts on the cv shaft (larger diameter like the early cars), and ????? splines on the stub axles, and what bolts/diameter on the stub axle.
The Turbos used similar to the last generation with a longer stub axle. Is the cv shaft larger in diameter than the 84 - 86 shaft??
Please verify that the above is correct. For the most part I am asking not telling.
Here is what I want to do. I want to use the larger diameter cv bearings to my race car. I have larger drive flanges (from a 84 trans) and larger stub axles (from an early car with the two pinholes drilled and tapped). What shaft should I get. Is the turbo shaft the same length. Can I use the carrera shaft (seems to be the same for less money ?) I am really looking for larger bearings not shafts. It has been the bearings failing on me, not the shafts.
See, this is why Wayne needs to do a transmission book.
Ed
Old 03-27-2006, 10:19 AM
}{arlequin's Avatar
Re: Question on early cv shaft liniage
i am pretty sure that my '73 has 4 bolts on the cv's....
dave
1973,5
Old 03-27-2006, 10:25 AM
long...but very informative thread.....there were many CV variations
---> Reconstructing Constant Velocity (CV) Joints
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-27-2006, 12:43 PM
