Door trim part ID help?
Can anyone help ID this little spacer that I seem to have on the driver's side but not on the passenger's side? I tried looking through the pelican catalog but couldn't find it. It's a little rubber piece that sits between the triangle window and the upper door trim panel. Car is a 1987 911 Targa.
Here's a photo of the piece on the driver's side: http://forums.pelicanparts.com/uploa...1143479332.jpg And here's a photo of where it should be on the passenger side (PO apparently had a repair done and didn't get it replaced, so the upper window trim has kind of been mangled a bit when overtightened): http://forums.pelicanparts.com/uploa...1143479355.jpg Thanks in advance! |
Bump
Found it! For future reference, this part is available from Pelican as this part #: 911-531-297-40-01C-OEM
| All times are GMT -8. The time now is 06:51 PM. |
