Window Problem
I have a 1990 911. For some reason the window in my passenger door stopped working. Could it be a fuse or do you think the motor went out? Any suggestions? Thanks.
Check the simple things first, Bill. Does the switch on the door work? What about the switch on the driver's door? They are notorious for going bad.
| All times are GMT -8. The time now is 08:47 AM. |
