Which wheel spacer??
O.K., here's the deal.....
I have a '76 912E, and I bought some boxster wheels (16x 6/7).
I recently got two varying opinions on what spacer size to use on the fronts. One Pelican has an 8mm spacer on a '76 911, and another has a 15mm on a '73 911. Both run 205/55 and225/50.
My questions is this:
Is there a difference, size-wise, between the two cars that would neccessitate a different spacer size?
The 15mm ('73 911) guy says that his size spacer keeps the fronts exactly in line with the rear wheels.
Neither guy uses spacers on the back.
I would like to get this right the first time. Could I get a reading and explanation on what the differences are between the two cars, and which way I should go?
Thanks in advance
Bill
Old 04-01-2006, 11:10 AM
"O"man(are we in trouble)
widgeon13's Avatar
I ran 16X7 Boxster wheels all around on my 74 narrow bodied 911, same flares as the 73 and 76 / 912. In the front I had 15mm spacers, I was not aware that you could get 225/50X16 on the back of a narrow body car but I suppose anything is possible if you roll the fender lip and increase neg camber. Hope that info is helpful.
Old 04-01-2006, 01:11 PM
