-   -   engine gurus help please!!!! (http://forums.pelicanparts.com/porsche-911-technical-forum/274502-engine-gurus-help-please.html)
Ruff1 03-30-2006 07:17 PM
I am rebuilding my engine by my mechanic and he is going to use 2.7L parts on my 2.4L 1973 911 motor. He said it will be very fast and will be faster than a 3.2L motor please give me your opinion here is the quote:
set 2.7L P&C's (used) $500
pair SC cams (used) $250
set 2.7L intake (used) $200
carrera tensioners (used) $400
carrera oil pump (used) $300
new bearing set (all) $300
gasket set $200
chain set $125
clutch $500
head work valves, porting $500
case work-insert,open ,deck, oil bypass $500
set powdercoated sheet metal, fan $200
25 hours re&re engine, clean, tear down, reassemble $1875
(at $75 an hour rate)
total---------------------------------------------------$5850
is this resonable and will my car be fast i dont know much about porsche engines it will be my first one being built?
Mr9146 03-30-2006 07:58 PM
Looks like you're getting the deal on case machining.
Jim Sims 03-30-2006 08:19 PM
What type of '73 motor are you starting with? CIS or MFI?
I don't see checking and polishing crankshaft, rebuilding connecting rods or rocker arms or re-facing the flywheel. Nor do I see new chain ramps or connecting rod bolts. Is this engine already apart? If so, what are the condition of the chain sprockets? What is being done to adapt or upgrade the carburetion or fuel injection and oil cooling external to the engine? Are the cylinder sheet metal baffles being trimmed? This is also a good time to replace all the fuel, vacuum and vent lines plus clean-up/restore the engine wiring harness. I suggest you purchase Wayne's Porsche 911 engine rebuilding book and educate yourself further before proceeding.
afterburn 549 03-30-2006 08:36 PM
Hmm, as for me I would never put in a used pump-maybe pistons but not used rings...and where is the cylinder re chrome (nikosol)? no one here wants to knock ya but you asked. A mag case might oughta be dowel pinned too. Line bore /over size bearings ..new exhaust valves...and I dont see where the "fast" is coming from.. SC cams will be better..loose 500lbs will really help. The mag case will absolutely need line bore and O.S mains..the bearings alone are at least 400.00 ( I know)I am thinkin you need to reload this picture b4 you open your wallet or you will do it twice if you cut to many corners and that wont be cheaper. To do a quaility eng. parts and machine work will run ez 5000.00 not counting Rand R and dwn and back togather.
Ruff1 03-30-2006 08:52 PM
i am starting with a 1973 2.4L with cis. The engine is good im driving it know but it smokes when i punch it and the valves are ticking loud!
Jim Sims 03-30-2006 09:00 PM
If a '73 CIS then it will also need new fuel injectors (or a least a correct set of used ones) and either different heads or further head work in the injector area; the '73 CIS fuel injectors will not work with a 2.7l CIS intake manifold.
Jim Sims 03-30-2006 09:05 PM
Buy and read the below referenced book; it will likely save you hundreds if not thousands of dollars and a lot of grief.
http://www.pelicanparts.com/catalog/ShopCart/BOOK/POR_BOOK_bkptec_pg3.htm
Jeff Alton 03-30-2006 09:43 PM
Well, just looking at he parts list I am not sure how it will be "faster than a 3.2" which has better fuel injection, the same cams and roughly 15% more displacement. You need to make sure the "uesd parts" you are getting are in spec for sure. I don't see any rings on your list either... The price seems fair enough but what if the heads need new valves? are you prepard for that extra expense for example?
If you want to chat offline about this, feel free to hit the email button beside my user name or send me a PM. I have a pretty good idea who is quoting you......
Cheers
RoninLB 03-31-2006 03:52 AM
SC cams in 2.4 cam towers ?
ianc 03-31-2006 08:34 AM
Not sure what the going price is these days, but $400 sounds a little steep for USED Carrera chain tensioners as well...
ianc
Ruff1 03-31-2006 02:15 PM
i was talking to my mechanic and he said most of the parts have about 10,000 miles on them!
Grady Clay 03-31-2006 02:27 PM
Just to check; your mechanic is in BC not LA and initials aren’t MM.
You are getting some good feedback here. I see some unnecessary things and others missing.
Best,
Grady
afterburn 549 03-31-2006 03:18 PM
If you want more pwr..(who dose not) now is the time to think about it as the labor is the same....use the $$ to your advantage....think.. think ..dwn the road here..twin plug ? higher C.R.?? If your going to buy pistons -CIS is not your best choice for power as they are in the way and 8.5 r.a. Just a thought from us that care,, dont want you in the world of "wish I had known that "" Cis can be made more better, is a good reliable sys (better then carbs) but a true stand alone I would think about....even if its dwn the road prepare the way now. Some will say go carbs- Mostly cause they worked real well but today's electronics is the way to go.(carbs are pesky lil aminals that belong in museums)LOL... I get the flak for that. T.m.O.- and I calls em as I see em-
RoninLB 03-31-2006 04:02 PM
Re: engine gurus help please!!!!
I ran forged 2.7 RS 8.5 pistons in a CIS instead of cast 2.7 CIS pistons for 40k miles without any problems. Passed smog no prob. Cast CIS pistons wear relatively faster imo.
RoninLB 03-31-2006 04:14 PM
I really don't understand your mechanic's logic on this one? I'd ask for an explain on this one.
It is possible to build a faster 2.7 street engine than a stock 3.2. I have one and it's been confirmed by 3.2 hot rod guys.
My carb gas millage is about 2/3 that of a CIS.
afterburn 549 03-31-2006 04:42 PM
OH believe me its possible as long as the other guy is not building his to beat yours. All things being equal the bigger displacement will Winn...but all things are never equal. My 2.7 will beat lot of 3.2 and bigger...but wont beat them all....depends whats been done . A hot rod is more then bore and stroke ..pancakes are more then flour and water.
Mr9146 03-31-2006 04:54 PM
Not trying to start anything but...
The problem with threads like this is you have an innocent guy asking an innocent question and getting a thousand different answers. He doesn't know who to trust when the person he should be trusting is his mechanic.
I'm starting to see a problem here - too many chiefs and not enough indians.
Hey, Ruff1, do yourself a favor and go with your gut. There's a thousand ways to skin a cat, and if you have faith in your mechanic you'll probably come out just fine. Just have faith and don't put too much stock in what you hear on this board ... read with skepticism and not blind loyalty. Hopefully you did your homework on the mechanic doing the work.
RoninLB 03-31-2006 05:51 PM
my writing is "stock 3.2"
afterburn 549 03-31-2006 06:00 PM
Well in a hoff I go
Zeke 03-31-2006 06:39 PM
Not an expert here by any means and I have to agree with Mr.9146. Just wondering, if you bring cams from another motor to this one, shouldn't one send the cams and rockers out for a quick refacing?
Also, someone 'spain to me the used intake runners, etc. Is the 2.7 CIs stuff larger? I see PET shows early 2.7 throttle at 56 mm and later at 63. Maybe I don't read that right.
emcon5 03-31-2006 06:56 PM
2.7 runners are larger than the 2.4 911T version. The 2.4 ones are pretty small.
Tom
afterburn 549 03-31-2006 07:26 PM
Lets all remember Ruff 1 asked will it be faster then a 3.2..So if it is now a poetic debate rather then fact NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOoooo I was trying to pt him in the right direction for fast rather then ill spent cash. rhyme that
Ruff1 03-31-2006 09:07 PM
thanks for all the help. this is the same mechanic that got my car running from a 15 year storage for under $1500 when other mechanics qouted me over $6000. he is very resonable with price and alway trys to save me money!
afterburn 549 04-01-2006 07:56 AM
Its a slippery slope, when to stop with the cash..we all want the most for the buck....If your just trying to make it run, that's a different ans. then will it be fast as a3.2
Grady Clay 04-01-2006 12:10 PM
Well perhaps. A good set of Mahle Nikasil 2.7Rs @ 8.5+:1 would be great. A set of worn Alusil at 8.0:1 … perhaps not. New rings are critical.
Why? First they won’t fit your cam housings. You can have your cams and rockers reconditioned and re-profiled.
Yes, it is substantially larger. You need to carefully evaluate all the 2.7 & 3.0 CIS systems. Size, compatibility, wiring, fuel plumbing and more are issues.
This isn’t too far off what new costs. I would first see what is installed. You may have the update Turbo tensioners with the later idler arm. Rebuilding those tensioners with new seals and safety stops is easily as good as Carrera tensioners and far less cost.
Unless there is something worn or defective with your 2.4 pump, I see no reason to change for a CIS street 911.
I don’t see rod bolts and nuts or jackshaft bearings.
I don’t see crank inspection, polishing/grinding, rod inspection/reconditioning.
gasket set $200
chain set $125
I don’t see any provision for sprockets. New chain ramps are an absolute mist.
clutch $500
What kind, what parts? Will it need flywheel machining or replacement? I would like to see pressure plate, spring center disc, TO bearing, pilot bearing, flywheel bolts, clutch cover bolts and at least an input shaft “dam seal” and drain installed.
New guides, valves, seals? New intake (different length for the later CIS) & exhaust studs? I don’t see machining to fit the 90 mm cylinders.
case work-insert, open, deck, oil bypass $500
Exactly what do they propose? I assume “open” means to enlarge the cylinder spigot holes to fit the 90 mm cylinders. I don’t see new cylinder studs. What if it needs align bore? Is that included? There is a plug, spring and piston needed for the oil bypass.
What is wrong with good cleaning, stripping and Plasticote?
I don’t see fresh high-temp paint for the heat exchangers.
Reasonable shop rate. I would figure on some more time to confirm proper piston-to-head clearance and piston-to-valve clearance.
I would add 50% or more for contingencies.
I don’t see any normal service parts – Oil & filter, air & fuel filters, spark plugs, connectors, wires, cap & rotor, points, fan belt, cam oil hoses, axle bolts, gaskets and Schnorr washers, heater tubes
I don’t see oil cooler cleaning/testing or inspecting the engine oil thermostat function.
With a 2.7, you will need increased engine cooling (even in BC). The easiest is the 11-blade, 1.82:1 fan ratio but you will need to scout out the parts (245 mm fan, 134 mm crank pulley and hardware). The other alternative is an SC/Carrera front cooler.
There are going to be two other major issues:
Surprises – oops, there are these other parts that need replacing.
“While you are there” – our lists try and cover most but there will be more.
I recommend you carefully read through these two books available from our host:
Dempsey, Wayne How Rebuild & Modify Porsche 911 Engines, 2003, MBI, St. Paul, MN
and
Anderson, Bruce, Porsche 911 Performance handbook, 1996, MBI, Osceola, WI
Both have good lists of parts and procedures. Combine these two into your plan.
Best,
Grady
