WydRyd's Avatar
Angry Cabrio headliner motor...
Cab guys,
My right side "lock-down" motor has siezed in such a way that the roof isn't completely secured all the way and I'm getting a lot of wind noise at speed.
How can I manually unlatch this motor so I can retract the roof and remove/replace it?
Also, can I manually latch it down tighter to seal the roof better, until I get a replacement motor?
Thanks in advance
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 04-04-2006, 04:17 PM
Dueller's Avatar
Not a cab guy but I recalled the owner's manual addresses "Emergency operation " on page 50
4. Operate the rocker switch until the indicator light goes out. If the electrical locking system for the top is defective, turn both locks with a screw driver until the locks are visibly locked. Indicator light off. The defect should be repaired by an authorized Porsche dealer."
Make any sense to you? Me neither, g'luck.
Old 04-04-2006, 04:33 PM
gduke's Avatar
Yes there are two holes in the headliner that you can insert a screwdriver and manuaully turn until the mechanism is fully locked. It takes alot of turns. I took out the headliner panel so I could lock mine faster.
Gary
1985 911 Carerra Cab 3.6l
1998 Dodge Ram
2004 Toyota Tundra Quad Cab
Old 04-04-2006, 04:48 PM
WydRyd's Avatar
OK thanks, I'll check it out
Merv
'89 911 Turbo Cab
Old 04-04-2006, 05:33 PM
