Coming out of storage
Any tips on bringing my car out of storage. I plan on draining the fuel (and replacing it obviously). I have the batteries out for charging. And of course will do a complete cleaning of every inch. Any other ideas would be appreciated. It has only been stored since mid-December so it's not like a ten year lay away or anything.
Thanks, Mike
Mike. 1972 911T, non-sunroof coupe. |
Non Compos Mentis
Since mid-December? I wouldn't even worry about the gas. Just go drive the car.
I recently started my 911 after sitting since before Decomber. I just hooked the battery back up and it started right away. |
I was thinking along those lines as well. It has carbs, would that be of any greater concern? I filled it no too long before putting it away.
I think you'll be fine. Mine was sitting since last Oct, went out yesterday and took it off the trickle charger, turned the key and it started with a second. Runs perfectly.
'82 911SC racecar '05 WRX STi |
<insert witty title here>
Same here. Put her to bed in late November, and no action in the engine since then until 2 weeks ago. A couple pumps of the gas pedal, turn the key and she fired right up after about 2 full seconds of turning over. Almost brings a tear to your eye...
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Man that's so strange, to think of not driving the 911 for months at a time. Oh well, it's sunny and 82 out.
This is NOT a slam, I'd just go nuts not getting to take her out whenever. Steve E
My life is great! Prev. rides - 87 924GT, 86 Carrera, 69 Targa, 85.5 944 track car, 86 951 84 Triple Black 911 - Current |
![]() Oh, it's sunny and 33 out.
RETIRED
Tsk, tsk looks like rain.....tomorrow. Time to put the top down and drive the pissoutta it today....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Clear blue skies and 30F today, I'm charging the batteries as we speak. I'll let you know how it goes.
Jaydubya, nice powder shot. It's been 7 years since I was on skis...way too long indeed. The last time was at Lake Louise, Alberta in March '99, it looked a lot like that. South Western Ontario is definitely not the place to be a skier. I used to ski at least three days a week when I didn't need to work for a living. What are you ridding in that pic?
Retired Member
I would change the oil, and filter. I wouldn't be to worried about the fuel.Try fuel stabilizer before you put the car away before this winter.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
I thought thats what they were, but the tip looks like it could be a snowboard. I was starting to think things had changed so much since I had skied that boarders were using poles too.
sorry to hijack this thread, but I will be in a similar situation in 2-3 months as the car has been run periodically every 3-4 months but the gas may be a year- 18 months old!
Should I dump the fuel or run it also- are there any addatives to help clean out any gum in the carbs if necc.? I will be having an oil change and valve check done before any serious driving!. thanks Ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001 1984 Carrera 3.2 IROC RSR look |
