DW SD's Avatar
Good source for fuel inlet hose (to tank from fender)?
I'm installing my Fuel Safe fuel cell, which bolts into the stock location. It has a stock style inlet pipe, but it is not as long as the inlet tube on the stock tank. Any have a good source for bulk hose? Summitracing sells goodyear inlet fuel hose (1 7/8") which would work, but they only sell 4' of it. I need about 1'. The factory hose is about 4", which I have, but it will not work for obvious reasons.
Anyone have an alternate source?
Anyone know the right diameter hose?
Mcmaster sells fuel hose, but only by 1/2" increments in diameter. The closest would be 1 1/2" or 2", neither of which will work, I believe.
Thank you,
Doug
1971 RSR - interpretation
Old 04-11-2006, 01:13 PM
