-   -   Cleaned my ICV, need input here. . . (http://forums.pelicanparts.com/porsche-911-technical-forum/274918-cleaned-my-icv-need-input-here.html)
redcoupe86 04-02-2006 11:41 AM
I cleaned it using isoprop. alchohol. the piece you can seen down in the holes spins freely, and when i shake it i hear a dull thud as i shake it back and fourth. However, it feels like its barly moving, like maybe a 1/16 of an inch or less, but I have no way of telling for sure.
Does this sound like an ok ICV.
redcoupe86 04-02-2006 03:23 PM
bump
Por_sha911 04-02-2006 09:48 PM
OK, I was hoping someone would answer this question so here's another bump.
ianc 04-02-2006 10:12 PM
Yes, me too. I've cleaned mine (and myself) out with alky and didn't notice much difference. I can't really tell a difference when I unplug the electrical connector from it, so hence it's difficult to tell whether it's actually working. I've searched a bit, but not found much definitive on the subject.
The Bentley has a rudimentary test, but I'd like to hear some more as well,
ianc
ZOA NOM 04-02-2006 10:23 PM
It should move more than a 16th of an inch. It is a valve, so it should open the airway and close it. The ICV can be opened up and taken apart. There may be some debris blocking it from moving.
redcoupe86 04-03-2006 10:24 AM
is there a bench test i can do to see if the plunger is working. Like hooking up a 9v batter the terminals?
ZOA NOM 04-03-2006 10:31 AM
You've already done the bench test by shaking it back and forth, looking for free movement. When voltage is applied, it vibrates slightly, but I think you would have to vary the voltage applied to get it to open and close.
redcoupe86 04-03-2006 11:19 AM
I see, so then even if the ICV was working fine, if you shook it you would NOT see the plunger in the window of the unit. B/C right now I see nothing when I shake it.
wcc 04-03-2006 11:26 AM
I cleaned mine some time ago but if I remember right it should be free sounding kinda like the sound of an empty paint rattle can. I didn't notice any difference after cleaning it either.
ianc 04-03-2006 11:38 AM
You fellows who are fairly sure yours are working:
What kind of difference do you see in the idle quality when you disconnect the electrical plug from the unit? More when cold than hot? Input here?
ianc
wcc 04-03-2006 11:50 AM
I have NO idea if mine is working or not. One evening I walked out to the car popped the engine lid and went to work. Unplugged it, unmounted it and took it to the work bench. Cleaned with alcohol and soaked it while I ate dinner then went back out to the garage and shook until it sounded like a paint rattle can and "free" sounding. Then I remounted it hooked up the wires and a few days later I took the little lady out for dinner in it. It ran the same. I know, I hate this word too, but I "assume" it's working. Car runs excellent....
EDIT: The engine was cold when I did the work.
redcoupe86 04-03-2006 11:55 AM
Bill,
when you shake it you say it sound like a paint can. How much movement do you think the pluger is moving back and forth?
wcc 04-03-2006 12:05 PM
It seems like it moved about 3/4 in from sound to sound.
Por_sha911 04-03-2006 03:26 PM
Mine sounded more like a dull thud than a free sounding rattle of a spray paint can. I wonder if it is clean or not. Can someone clarify what a new one sounds like? I think that there are several of us that are trying to determine what the correct sound should be.
redcoupe86 04-03-2006 03:44 PM
still confused . .
just got home and looked at the ICV again.
Now i can see the piece that rotates, it rotates freely and smoothly about 1/2 turn. If i stick a pencil with an eraser donw in there and hold it tight will shaking it i get not "rattle" or "thu" up and down whatsoever. I've heard of the plunger, is this the same piece as the rotating piece or is it separate? Can someone explain the exact operation?
MAS956 04-03-2006 04:04 PM
Reinstall and Drive It
It's a 10 minute job to reinstall the ICV - now that you've cleaned it out, why not just put it back it and see how she does?
redcoupe86 04-03-2006 04:12 PM
well, its a little more complicated than that. I also have my AFM off and will be switching that out (hopefully, if he'll let me) with a friend of mines '87. Also, he as an CO meter that we are going to set my idle mixture with because i fiddled with it a while back when i was trying to diagnose a misfire (turned out to be a plug not pluged in all the way). So I have several variables im trying to weed out. I figured if i could get a handle on this ICV i'd have a better direction.
Im just not sure i understand how the internals work to see if what i see is normal or not. When I cleaned the ICV the alchohol came out clean, no debris.
ZOA NOM 04-03-2006 04:59 PM
Originally posted by redcoupe86
still confused . .
That's all I look for, It should work fine. It's function is to allow air past the throttle plate, which is modulated by the ICV valve. This is how the Motronic system controls the idle speed. The voltage applied to the ICV varies with the program in the DME under different conditions; ie: cold start, or normal temp running. As the voltage applied changes, the valve opens or closes off the bypass tube.
If you are chasing a "hunting idle" problem, I would strongly suggest you confirm your CO mixture setting with a gas analyzer before making any further adjustments or replacements. The mixture is very precisely metered through the AFM, and if not set correctly, you can be replacing parts that don't fix the problem.
edit: I should read all the posts before running on about stuff that's been done.
Anyway, I just resolved a "miss" problem after wrangling with the mixture, AFM, Dizzy, etc., only to find a poorly firing plug. Replaced the plug, and all is well. This stuff really does all seem to work together, so the symptoms of failure often point to just about any part of the whole complex system.
redcoupe86 04-03-2006 05:24 PM
I hope its just an "hunting" issue. This all started when I started the car the other day and the bounce up and down wildly between 800 and 1500 rpm or so. Then as i started pulling away the car when to about1200 rpm +/- then bucked. It would also start pulling, and then it was like the ignition cut out - nothing for a second or so, then the engine cut back in. I've got an DME on the way, and i've done a just about all the resistance checks i can, and they all come up good. Even the ICV. The cleaning bit was more of an insurance policy if you will. However, i kept reading about a plunger than could get stuck and i wasn't sure what the plunger was or what a stuck one would feel like.
ZOA NOM 04-03-2006 05:33 PM
Sounds like you have a series of problems. I would start with replacing the DME relay (I hope that's what you meant, not the DME itself). Then get the mixture set correctly. If you still have a hunting idle, I would suspect the AFM. It has a potentiometer inside that can get a worn spot that causes the voltage pickup to be erratic, which can cause all sorts of issues. There is a way to re-position the pickup arm that glides across the potentiometer that I would try before replacing the entire AFM. By far, however, my CO mixture setting has had the greatest affect on the performance and idle.
jbrinkley 04-03-2006 05:44 PM
it hums a little with key on. plug it back in to the connector, even with all the afm stuff off, and turn the key, you'll here it vibrate.
you might have to plug the afm back in to, but I doubt it
ianc 04-03-2006 05:54 PM
I don't think the ICV is going to be the issue if your idle is swinging from 800-1500. I believe there is window within which it will correct, but it is much smaller than this.
Following up on it is a good idea, maintenance-wise, but I think you'll most likely find your problem elsewhere,
ianc
redcoupe86 04-03-2006 06:03 PM
No, I dont think it will be the ICV in the end, but im trying to eliminate as many varible as i can. I tried testing my fuel pressure, but the stinking pressure gauge fitting doesn't fit the rail.
Zoanas: its is indeed the relay i am replacing.
I have anthor thread dedicated to this problem, but i started this one just to resolve the ICV questions i have.
In that thread i talk about checking the CHT (I have then new 2 wire) and even the flywheel senosrs. Then sensors looked good with the cable soft and plyable with no cracks. However, the end of the sensor had a small pile of metal filings built up in a little mound on the end of the magnetic pick up. Mayby stuck up about 1/16 of and inch or so. I wondered if this could cause any pickup issues.
I've read up on the AFM "fix" and I will be trying that if all else fails. Im not sure how to get the black cover off. Do you just pry?
redcoupe86 04-03-2006 06:05 PM
Hey Jerry, it does indeed hum. Cant wait till you get back to use that fancy dancy meter of yours:D
ZOA NOM 04-03-2006 06:18 PM
It's usually sealed with a bead of silicone. I use a 2" wide putty knife and tap it under the edge of the cover all the way around. I have split the edge of the cover, but it still seals up when you put a new bead on re-installation.
john walker's workshop 04-03-2006 06:26 PM
the wildly fluctuating idle is usually because the idle air screw is in or out too far from the nominal setting and the ICV is trying to correct it. turn the idle down until it stops surging. it also could be the throttle micro-switch is not working. listen for a quiet click upon opening the throttle and test it at the plug with an ohmmeter. i replaced a AFM today on a 84 because it was very touchy moving the car around slowly, and would be very easy to kill the engine. i cleaned the ICV first and even put on a good used one, but it was the AFM. night and day difference. a check for ICV function is to rev the engine at idle and see if the valve responds with a quick surge as the RPM drops again.
redcoupe86 04-03-2006 06:47 PM
I should be clear here. The wild surging only happened once (along with the engine cutting out and back on). However, the day before that happened I DID turn UP the idle speed by a half turn or so to try and fix my typical symptoms. My typical idle problem symtoms (prior to the wild surging incident) are a rough irregular idle thats seemed to to surge up and down a little, by "little" i would guess 20 rpmor so. The engine just didn't sound steady would be another way to put it - until it warmed up then it was fine. When i turned up the idle speed the surging went away, however the next day i had the incident with the wild rpm hunting and the engine cutting out and back on.
BTW Mr. Walker, I do hear a click, but how do you go about checking the OHM reading and what am i looking for as far as readings go. Do I just unplug it and test the resistance.
john walker's workshop 04-03-2006 07:00 PM
the wire from the micro-switch goes to a two pin plug to the right of the throttle housing. an ohmmeter will just go back and forth from open circuit to some small resistance as you work the throttle.
redcoupe86 04-03-2006 07:05 PM
I went back to my notes on all my tests i've done thus far. I did indeed do this test and it checked out.
