-   -   Another shift coupler question (http://forums.pelicanparts.com/porsche-911-technical-forum/275040-another-shift-coupler-question.html)
Toothzilla 04-02-2006 09:25 PM
I can't get my porsche out of reverse, the first thing I was told to check was the shift coupler. Everything looked solid, but I removed it to check the bushings.
Seems like there's a lot of slop in the coupler. Is that how you know the bushings are bad?
TIA
chris
Wil Ferch 04-03-2006 06:16 AM
Slop in the coupler itself is ( unfortunately) normal...do a search where I mention this several times....
Wil
Motorhead-45 04-03-2006 06:22 AM
The aftermarket bushings I purchased from Pelican do not have the "factory" Porsche built in slop.
Wil Ferch 04-03-2006 07:20 AM
The original poster is advised to look at adjustment as well as the "other" area for bushing wear..like the ball/cup directly under the shift lever...
If everything worked before but you can't get it out of reverse...I'd suspect adjustment first....
- Wil
Toothzilla 04-03-2006 01:07 PM
After taking the coupler out and putting it back in, it now shifts correctly.
What I was looking for was how do you "know" it's time to replace the bushings?
