front suspension torque specs?
I swear I saw a post which contained an image of the shop manual with the front suspension torque specifications. I searched and searched but could not find it. Does anyone have it handy?
thx
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
The large bolt that holds the crossmember in is 66 ft/lbs. The three bolts on the front of the A-arm are 35 ft/lbs. The tie rod nut is 33 ft/lbs
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
dedly - thanks jeff
Oh..what about the bolts that hold the brake caliper to the strut??
Those are 52 ft/lbs
Cheers
