74 and 81 front condensors compatible?
Does anyone know if these front ac condensors are compatible?
Thanks- Craig Backer |
74 were all after market condensor, even if the dealer installed them, 81 were all factory installed condensor.
You can probably make it fit if you are handy. The good news is they are probably all flare fitting and not o-ring fittings. |
Does anyone know if they are both flare fitting for sure?
Look at it and you can tell. They started o-rings with the 84's
| All times are GMT -8. The time now is 09:44 PM. |
