911 Mono Block Brake Upgrade
I am concidering the Boxter Mono Block Caliper upgrade for my SC. It is much more reasonable than Turbo's or Big Reds with a 35% pad surface increase. Has anyone gone to these and do you have success or disapointment stories.
Time to do a search!
IMO the boxster brakes are about as good as standard carrera brakes, which are way cheaper......There is a reason that the turbo brakes are more money... What are you using your car for? Are you sure you need to upgrade the brakes in the first place? Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler |
