View Poll Results: Which Brand of Sway Bars provide best performance
Weltmeister 0 0%
Tarret 8 100.00%
Voters: 8. This poll is closed
Blk95993's Avatar
Porsche Crest Sway Bar Opinions/Feedback
Bout to throw down on a set of sway bars. My options are Weltmeister and Tarret. Any feedback regards the product or other products would be greatly appreciated. I run AutoX and DE events. Thanks!
Porsche-Less at the moment....
Old 04-04-2006, 10:13 AM
PRO Motorsports
Tyson Schmidt's Avatar
The Tarrets are easier to work with when it comes to aligning the car, and removing drop-link pre-load when corner balancing. They are also much lighter.
For not much more than the Tarrets, you can get the Smart Racing bars, which are the best.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 04-04-2006, 10:26 AM
Jeff Alton's Avatar
I have used the larger carrera bars, the Tarret ones and the SRP ones. Yes, the SRP ones have more options and *maybe* are a litte better designed, but the weigh heck of a lot more too. That said, I am happy with them on my car.
Cheers
www.turn3autosport.com
Old 04-04-2006, 10:47 AM
cycling has-been
bkreigsr's Avatar
man, is this your lucky day?
you need this Tarett for your rear!
http://www.pelicanbbs.com/showthread.php?threadid=273655
Bill K
Old 04-04-2006, 12:31 PM
I would suspect that given the same bar OD, they would provide the same anti-roll characteristic.
Other factors might include:
- Price
- Ease of adjusting settings
- Weight
- Quality of parts and hardware
- Optimum geometry
(not in any specific order)
What does "performance" entail?
If it were not for the puny, 5/16" socket head screw drop link attachment to the spring plate (rear, of course), I'd say why not? Tarrett uses a 3/8" bolt. It's a sway bar folks. While nice to have, a SB doesn't have to look pretty, just very functional.
Sherwood
Old 04-04-2006, 04:09 PM
I just took off the Weltmeisters that came with my car and replaced them with a set of Smart Racing bars. The difference in quality was pretty astonishing; CNC machined aluminum vs. bent sheetmetal. I have not seen the Tarrets. I ended up with 31mm in the front and 27mm in the back, considerably stiffer than my 22mm Weltmeisters, and lighter.
rickdm
rickdm
'87 Carrera
'91 Miata
'78 SC (ex)
Old 04-04-2006, 06:03 PM
Blk95993's Avatar
Who sells smart racing bars? How much can I anticipate spending?? Thanks for the feed back.. Did you upgrade your torsion bars as well?
Old 04-04-2006, 06:39 PM
I was all set with SRP ones then I found a set of TRG ones.
SRP is nice in that (as I understand it) it uses all metric hardware.
The geometry, without having them side by side, seems to be as good/better than the TRG ones which had been one of the better ones out there for a long while.
I think the SRP ones are about $1300 for the set (front & rear) and you can get it from them.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 04-04-2006, 07:24 PM
You can buy the Smart Racing products directly from them or from a local dealer. They always have ads in all the Porsche magazines. I think I paid $625 for the front and $575 for the rear. Not cheap, but I suspect they have a pretty good resale value.
Right now I am running 23/29mm torsion bars in the car, and at some point will probably move up to 31 mm in the back with revalved Bilsteins (currntly running stock Sports). I still drive the car a little on the street and I am not sure I am quite ready to make it that stiff.
rickdm
rickdm
'87 Carrera
'91 Miata
'78 SC (ex)
Old 04-05-2006, 04:16 AM
