Help ID oil leak
I finally am getting around to fixing the various oil leaks since my rebuild almost a year ago.
The biggest leak I find is on top of the engine. I find that the oil breather hose clamp is loose (red circle). From the picture attached, do you think the oil pressure sender (blue circle) (it's a 92 964 C2) could have leaked also? I replaced the oil sender o-ring during the rebuild, but I am seeing a film of oil in the area around the oil breather and pressure sender area. I am wondering should I replace the sender o-ring seal again. If I should replace it, what can I do to prevent further leak? Sealant? Silicone?
What are your thought?
thanks,
anthony
Old 04-04-2006, 09:15 AM
I just replaced an oil pressure sender unit that was leaking right at the point where the wire comes out of the top. It solved a major leak. Now I only 10 more minor leaks to go!
Old 04-05-2006, 11:09 AM
Since no one replied, I replaced the hose clamp on the breather tube, cleanup the oil, and put everything back together. Don't want to mess with the sender until I run the car for a while to see if the breather tube was the only cause to all the oil.
anthony
Old 04-05-2006, 12:14 PM
xclaim's Avatar
REPLACE IT!! Its so cheap, I think it is best to take care of it while you can. I replaced my themostat o ring, oil pressure sender, breather gasket, and breather hose also because it can become crystalized and very brittle. I didnt do a full engine drop, I just pulled my fuel injection, throttle etc.. to access it.
Good Luck
Old 04-05-2006, 02:07 PM
I did replace the o-ring less than a year ago when I did my rebuild.
I also tightened various oil hoses clamps as they were also leaking/sweating.
Old 04-05-2006, 03:20 PM
