bigrubberjeep's Avatar
Quetion on tire tread wear.
I use Yoko ES100's on my 911Turbo Look, and I was curious when does one get new front tires? Mine look decent, still have visible goves on the inner tire side, however it's quite obvious the difference vs the outside tire tread. Only way I could discribe it is the inside looks like it has 10-15% of life left, the outside looks like it has 60-75% left. Is this common for a car that get's tracked 4-5 times a year with about 12K-15K miles on the tires?
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 04-05-2006, 01:15 PM
You can smoke a set of tires in one event. Sounds like these tires a past due...time for new shoes.
Your uneven wear pattern is likely due to the negative camber you're running.
Warren & Ron, may you rest in Peace.
Old 04-05-2006, 01:31 PM
Old 04-05-2006, 01:40 PM
Automotive Monomaniac
Emission's Avatar
Sounds normal.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 04-05-2006, 01:48 PM
Keep in mind these are street tires, not R compound so I should expect to get 2 more track days out of them right?
I agree the wear issue is from the negative camber, I guess my question is in regards to the huge difference, I was expecting maybe a 40/60 ratio not 20/80
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 04-05-2006, 02:00 PM
It sounds normal to me, 12 - 15K miles on them - you have no problem!
Old 04-05-2006, 02:15 PM
