3.2 Tire Pressure
Just checked the PSi in my Bridgestone SO2 tires on the rear of my 89 3.2 coupe. Have driven just over 100 miles since buying the car swith 36 PSi so still getting a feel for them.
When having the pressure checked today at the garage had the rear tires filled to 44 psi per the manual, although a check of the PSI in the rear tires then revealed they were at 36 Psi. The car seems to float a bit now in the rear, of course the ride is a bit harsher (which would be expected). Might play with the rear pressure a bit and was wondering what others have found regarding this. Do only recreational spirited driving in dry conditions only. Thanks. Front remains the same at 29 PSI
Euro 1989 Carrera 3.2 Paint Code L 693 Stone Grey 45,000 kms logged Last edited by Rad Hatter; 03-25-2006 at 07:51 AM.. |
Recreational User
Disregard the manual's specification of 44 psi for the rear. It's a typo! 36 psi is correct for the rear, which you can also find on one of the metal decals in the engine compartment.
wow great stuff ...many thanks Dave
Euro 1989 Carrera 3.2 Paint Code L 693 Stone Grey 45,000 kms logged |
36
Yep, 36 psi rear is correct, 44 is a typo. The PO of my car did not read that and ran the rear tires at 44. I guess it didn't hurt anything. Great looking car by the way.
'86 911 Sunroof Coupe '91 Miata '77 BMW R75/7 |
What is your Tire size??
29/36 is for 6/7 Front and 7/8 rear (15" or 16") I think the Turbo or Turbolook with 7" front and 9"/16 rear has 29/44 so it depends on your tire size... jo |
44 is absurd for any Porsche...especially since these are "cold" pressures and will increase 6 psi when "hot" ..... might as well be running bicycle tires for all the contact patch you'll have...
Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
I would suggest you play around a little. The 6-7 pound difference in the manual is designed to build in understeer for "safety".
2-4 psi difference is worth checking out. Simon
85' Carrera 3.2 02' Mazda MX5 |
Hi Wil, maybe its absurd..i use a bit less anyway, but its definitly what Porsche said. ![]() 911 6J / 7J / 8J x 15 or 16 and all the old ones 29 front 36 rear but for 930 and Turbolook models with 7J x16 and 9J x16 rear its 29 front and 44 rear. For the 930 Turbo S - 36PSI front!! I dont know if it only depends on the higher weight or in the tire size: But its a fact and no typo error: 2,0 bar = 29 PSI 2,5 bar = 36PSI 3,0 bar = 44PSI Vorderachse= front Hinterachse=rear its also on the decal (engine bay), take a look on a 930. (or here: http://www.carclassic.biz/picturepages/porsche23.htm ) I runs definitly better with less than 44PSI on 9J X 16 and 36PSI is never totaly wrong Jo Last edited by exponence; 03-27-2006 at 02:47 PM.. |
Lots of people have good luck with 32/34
My mechanic has suggested 34/40 front/rear for my 85 Carrera. I have 205/50/17 and 255/40/17.
I run 36 for the rear and 32 for the front
Howard 2003 996tt 1997 911 Coupe Artic Silver (sold) 1988 Black 911 Coupe (gone but not forgetten) |
While the "recommended" tire pressues for my Carrera is 29 F, 36 R, I've got to believe that pressure was relevant to the tire technology at the time.
My car was delivered with Dunlop D40M2's on 6J/7J's on 16's, that was 19 - 20 years ago. Every service shop I've ever been to, recommended a higher pressures in front tires but still maintained that 36 R was adequate.
The Fox Carrera |
coolcavaracing.com
So, 2,5bar/36PSI front & 3,0bar/44PSI rear??
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Friend of Warren
For anyone I would suggest you start with the recommended pressures of 29 front/36 rear and see how the car feels. After that move up and down a couple of pounds at a time and see if the car steers better or worse. Don't rely on what others are doing or have done. Each car/tire set up is different.
Kurt V No more Porsches, but a revolving number of motorcycles. |
The 930 is also different, but what Kurt said is correct... 29 front / 36 rear...that is never totaly wrong.. the rest is............ ![]() Jo |
Or maybe Kroggers is obliquely asking the bar vs psi relationship...
In that case...yes, since 1 bar = 14.5 psi - Wil
coolcavaracing.com
Yes, thank you Wil
29-36 wow what a change
22-26 36 32 So I went 29-36 and wow what a marked difference. Much lighter and although a bit floaty I got used to it and really like this set up. 17 inch Bridgestone SO2"s 205/50/17 and 255/40/17. Thanks Kurt mate
Euro 1989 Carrera 3.2 Paint Code L 693 Stone Grey 45,000 kms logged Last edited by Rad Hatter; 04-07-2006 at 09:58 AM.. |
![]() Jo Last edited by exponence; 04-07-2006 at 10:33 AM.. |
