| jpnovak |
04-05-2006 04:23 PM |
Yes, I did. I had to start somewhere. The venturi will speed up the air through the carb body. this provides more vacuum to suck fuel out (hey its a carburetor). If the venturi is too small it will choke off the engine by not allowing enough air past. I suspect this may be a tranition from laminar to turbulent low that prevents the fuel from being sucked out thus reducing power. I could be wrong here. My fluid dynamics are weak.
Tas, I expect that V8 manufacturers are what you are referring to and assume that it is because most consumers can't add and multiply. Its all about marketing - bigger is always better - Right?! Think again. It would be common for people to get a carb that is too big for the engine. This might make more high rpm HP but will likely have poor metering signals for low rpm cruising and idle. It is also common for street engines to be delivered with small carbs. This helps low speed drivability and gets better gas mileage while also limiting HP. Going larger can free up some power.
no way around it, the carbs must be matched to the particular engine specs. Don't forget that cams and compression ratio factor in as well. There are many places to get the formulas for finding the correct size carb for your motor. I know Bruce Andersen's book has them. I can't remember them off the top of my head.
John, I also mispelled your last name. It has since been corrected.
