1978 SC Wiring Harness installation
In looking at the parts diagram here I see that each wire end has a letter, A - M, etc. Are these letters on a new wiring harness to enable installation? If not how would I know which wire goes where. Learning as I go.
Thanks,
Tom
Old 05-25-2007, 10:18 AM
Should have read "Engine Wiring Harness"
Anyone install a new one of these?
Old 05-25-2007, 04:06 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
which harness end are you talking about? engine side or 14 pin connector, alt?
Marc
Old 05-25-2007, 06:13 PM
Engine side. Looking at the parts diagram end wire end has a letter assigned to it.
Old 05-26-2007, 05:03 PM
rattlsnak's Avatar
just to confirm, you're talking about the harness that plugs into the 14 pin connector, then goes over towards the engine, where it branches off to the coil, sensors, sending unit, alt, etc? if so, its pretty much a plug and play. If you overlay across the motor, everything lines up to where they hook up.
Marc
Old 05-26-2007, 07:14 PM
Great, just wanted to make sure. Color coding would not work for me because I'm color blind.
Thanks,
Tom
Old 05-27-2007, 10:28 AM
rattlsnak's Avatar
post some pics if you are unsure about any connectors and we will help you more with it.
Marc
Old 05-27-2007, 07:24 PM
