Blk95993's Avatar
Major Mtc-whats involved
Need to baseline my car and do a major maintenance. Car has 125k on the clock, top end rebuilt about 10k ago, and is in desperate need for a good refresher before I throw her on the track at road Atlanta in June...
Outside of the following, is there anything else I should be aware of or need to address?:
-valve adj
-oil change
-fuel filter
-oil filter
-plugs
-cap
-wires
Thank you for your feed-back. Am hoping to do it myself, but I don't want to take a chance-so I may pu$$ out and take her down to my mechanic. After I get her up to par, then maybe Ill tackle follow up maintenance
Porsche-Less at the moment....
Old 04-08-2006, 11:17 AM
Dueller's Avatar
Brake pads/fluid/lines
Clutch OK?
Change diff lube?
Old 04-08-2006, 01:04 PM
you might want to clean and re-pack the wheel bearings or replace the bearings if they are original. You definitely want to put in new brake fluid with a race spec fluid and get a higher temp pad. Stock pads will get to hot and fade away on you. (guess that depends on run group and braking skill level)
Look at tie rods, sway bar bushings and shocks. All that will likely be checked at tech and you don't want to find out then that you need something replaced.
Tony G
2000 Boxster S
Old 04-08-2006, 01:17 PM
