Mike69T's Avatar
Supensions and Brakes...Set me up!!!!
So i am finished with all the body work and it's being sprayed this next week. It's a 69t to RS conversion by the way.......Well it's mostly going to be driven as a street car but I like to have a tight suspension because I am moving out to the twisty country very soon. So set me up with what you would put on a car like this. It's basically all going to be redone, as I think the suspension is stock and the brakes are locked up.
69T RS clone in the making
Old 04-11-2006, 04:18 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
basic performance minded upgrades include: bilstein struts/shocks 23&30 TBs, Tarrett 22 SB, Elephant strut brace, turbo tie rods.
Your brakes are totally dependant on your budget. Too many options. Set your self a cap, and we can help you find the best solution. (and then we will promptly help you go over your limit! )
Marc
Old 04-11-2006, 07:01 AM
Mike,
Suspension is soooo subjective so be prepared for the gamut of opinions. My SC at about 2530lbs felt great on the street with 22/28 T-bars and Bilstein Sports all around. It was plenty firm, very controlled, yet not jarring. Presuming your RS Clone will be even lighter, I'd consider either 21/28 or 22/29, depending on how firm you like it. Lots would say 27 or 28 on the rear bar in my stated combination ...I like having just a bit more rotation when I call for it, but keep in mind that I've got 225/245 rubber; if you've got less on the rear, you may want the more conservative rear bar.
For reference, I've also got the Carrera sway bars (22mm/21mm) and like them a bunch! They are excellent street sways. You can pay more for adjustables, to be sure, but the price difference is very serious so that's up to you. The 22/21s offer great roll-stiffness at the track (and street), and are the best bang-for-buck, IMHO. Ooops, though with your 69, I don't think these will work ...check on that.
Personally, I wouldn't go any stiffer for a "mostly street driven car" as my SC (a dedicated track car that is streeted on occasion) now has 31s in the rear. While tolerable, I wouldn't want to street with that on a regular basis (killer on the track, though!!! ).
I'd definitely do the suspension bushings ...to PolyGraphite or ER's PolyBronze? ...well, I'll let you sort that one out
Don't forget to get a quality alignment. A good balance for crisp handling w/o ripping through tires is in the -1.5 degrees neighborhood. And of course, a corner balance.
Can't make any suggestions on brakes as I don't know enough about options for a long-hood to speak to that. Hope this gives you something to think about.
Edward
993: retired Trackmeister, now daily driver heaven
911SC: resident Trackmeister-in-progress
Old 04-11-2006, 08:54 AM
user & abuser
http://elephantracing.com/suspension/packages/911packages.htm
this is how u get an amazing suspension setup..
you go to the pros...and get all the parts pre-dialed in..
they price is competative......trust me...as i did each set on my own...and i'm probably at the price....just nto as well set-up...
cheers
Nick
vini vidi vici
Old 04-11-2006, 09:30 AM
Dueller's Avatar
As far as brakes, I've found Bill V's R/D to be excellent...just a matter of how fast you wanna spend (stop)..
http://home.nycap.rr.com/wmv/
Old 04-11-2006, 09:48 AM
lateapex911's Avatar
ANd get the WEVO SPS setup for the back, sounds expensive until you add the parts that you are getting nd compare what it would cost otherwise, EXCEPT, the WEVo stuff is as well made as anything that you've fantasized about. (for a car!) Also, go with Smart Racings swau bars ....they make the weltmeister stuff look silly.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 04-11-2006, 09:51 AM
Mike69T's Avatar
thanks for all the imput. As far as brakes go, I was thinking about just getting new rotors and rebuilding the calipers. Is it worth the extra money to upgrade the calipers? I will just be driving the car around the country roads, the car might never even see a track.
Old 04-11-2006, 12:30 PM
Send a message via AIM to johncarlos2003
good idea- i wouldn't upgrade- new rotors, fresh pads, rebuild calipers, flush fluid, -- you should be good- especially if just doing spirited driving on the backroads- post pics when done! good luck
john-carlos ynostroza
88 G50 coupe, black/black
Old 04-11-2006, 12:43 PM
